MMI3G Red Screen HELP Please!!!
  • MMI3G Red Screen HELP Please!!!
    Hi all, i am new here, i am desperately trying to find out what's the problem with this, played with the engineering mode for like 5 minutes the day i got my ODBeleven and pressed something
    I am trying to avoid pulling half the dashboard out and have to find laptops with Windows.
ID:	1870039Click image for larger version
    19 Gateway
    System description: GW-CAN-L-FR-M
    Software number: 7P6907530K
    Software version: 6032
    Hardware number: 7P6907530G
    Hardware version: H13
    Faults:
    U140B00 - Energy management active
    Intermittent
    Priority - 7
    Malfunction frequency counter - 2
    Unlearning counter - 195
    km-Mileage - 165915 km
    Voltage terminal 30 - 11.5 V
    Voltage terminal 15 - 1.1 V
    Control module temperature - 32 °C
    System status - Awake_Timer_active
    Terminal 15 status - Off
    Terminal 15 status via CAN - Off
    IN ZAS Kl X - Off
    Engine running - Off
    IN ESP Stillstandsflag - standstill detected
    Datenfeld - 3
    date - 2023-06-15 04:43:37
    5F Multimedia
    System description: H-BNT-RW
    Software number: 7P6035764E
    Software version: 0816
    Hardware number: 7P6035764A
    Hardware version: H40
    Faults:
    No trouble codes found
    5F Multimedia
    Faults:
    00658 - Operating unit
    Intermittent
    priority - 5
    frequencyCounter - 1
    drivingCycle - 196
    02259 - Front information display control head
    Intermittent
    priority - 5
    drivingCycle - 196
    km-Mileage - 165916 km
    date - 2023-06-15 08:24:47
    Intermittent
    priority - 5
    frequencyCounter - 2
    drivingCycle - 196
    01 Engine
    System description: 3.0TDI EDC17
    Software number: 7P0907311C
    Software version: 0005
    Hardware number: 4G0907401
    Hardware version: H41
    Faults:
    01 Engine
    Faults:
    U140A00 - Terminal 30
    Open circuit
    Intermittent
    Priority - 2
    Malfunction frequency counter - 1
    Unlearning counter - 255
    Engine speed - 0.00 1/min
    Normed load value - 0.0 %
    Vehicle speed - 0 km/h
    Coolant temperature - -40 °C
    Intake air temperature - -40 °C
    Ambient air pressure - 0 mbar
    Voltage terminal 30 - 0.000 V
    Dynamic environmental data - 20961D13BA0000000014B3000011390000133A000012FB0000
    P068A00 - ECM/PCM Power Relay De-Energized Performance - Too Early
    Intermittent
    Priority - 2
    Dynamic environmental data - 20961D102A000011EA00106C0011C60011F800117600100D00
    Look in your history to see what you did and reverse it.
    So many just "do things" without a clue and then come on forums asking how to fix it.
    The Facebook OBDELEVEN forum is just a list of "Ive done something and dont know what i did"
    "How do I fix it"
    Also like here they fail to say what VEHICLE they are working on.
    There are about 100 VAG vehicles that this device works on and not all of them are the same and there are at least 1000 settings that can be made.
    How are people supposed to answer questions when you dont provide the correct info.
    A helpful suggestion is. Get a sheet of paper and as you do things WRITE DOWN WHAT YOU DO.
    I still do that even after using one for 4 years. Saves fixing what shouldnt be broke.
      Reversing whatever was done will not get it out of emergency upgrade mode you need to reload the firmware.
      It's an RNS850 need to put the correct firmware onto an sdcard and insert to allow it to load.
      mibsolution.one should have the firmware.
        Bless your injections mate, thanks a lot!!!
        Pure gold and str8 to the point.
