i was hoping some could help, and/or tell me why, when i do a VCDS (v18.9) Autoscan, it doesn't show Address 55 Headlight Range?
i even tried scanning with car engine running and the lights on AUTO.
no luck.
i'm using a Hex-Can cable.
there are no issues scanning the other bits.
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47 4B 52 5F 6C 6D A5
i need to be able to change the Coding value of the Subsystems within Headlight range.
however i don't understand why the vcds scan is not picking this up.
any ideas?
my car is MY17 Superb 220. its factory fitted with Xenons.
i've successfully got HBA coded via VCDS.
below is an example of Address 55...
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 06D602007F010000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 4084F5F7DBD5DA3E1D-8014
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0013
Coding: B30000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0013
Coding: B30000
No fault code found.
no luck.
any ideas?
Coding: B30000
Coding: B30000
