Engine Oil!
  • #31
    In answer to your oil number question:
    The viscosity of any oil changes with temperature. The higher the temperature, the lower the viscosity—the oil thins out. On the flipside, the lower the temperature the higher the viscosity. Because of this, the Society of Automotive Engineers (SAE) has established a series of viscosity classifications that establish oil performance at 100 and 0 degrees Celsius (212 and 32 degrees Fahrenheit, respectively).
    Highs and Lows
    Low-viscosity oils flow better than high-viscosity ones—the lighter-weight fluid is easier to pump and therefore circulates faster through the engine's various galleries. Low-viscosity oils also maintain a lower oil pressure, but the oil pump delivers a greater volume through the galleries than it would with thicker (higher-viscosity) oils. Heavier oils also tend to operate at higher temperatures because the oil pump has to work harder to force the lubricant through the system. Oil does not compress readily, so the added pressure increases the temperature. In the end, high-viscosity oils maintain a higher oil pressure, but the pump delivers a smaller volume of oil.
    Multigrades
    Multigrade oils typically begin as base oils, such as 10W. Then viscosity-index modifiers (polymers) are added in an effort to stabilize the viscosity. This allows a 10W40 oil to flow like a 10W at cold temperatures and a 40W at higher temperatures.
    \'95 Golf VR6
    • #32
      Nice one!
      Good explanation. In simple terms: It's better to have a large volume of thin oil circulating at a low pressure than a small volume of thick oil circulating at a high pressure. Gotta remember that oil not only lubricates but cools metal-to-metal surfaces.
      • #33
        OK!
        No worries, I got some Mobile 1 5W40 today at supercheap auto.
        Gonna do the service on the weekends.
        Hope i am doing it right??!!
        Cheer,
        Fred
        ...BiG DuB...
        • #34
          5 weight is too thin for vr6
          I use 15 40 grade for 12v vr6 engines
          • #35
            oh not the vr6..the 2L GL
            is it too thin still??
            Cheer,
            Fred.
            ...BiG DuB...
            • #36
              fred
              make sure you change your oil filter at the same time
              \'95 Golf VR6
              • #37
                Thx everyone for the help,
                I sure will change my oil filter when I do change the engine oil.
                Thank You,
                Fred
                ...BiG DuB...
