Hi all,
I have a question about the launch control on my golf R.
I purchased the 2011 stock Golf R MK6 for just about a month, it is stock. (not sure about now as it is with the specialist today for the ECU tune and high pressure fuel pump).
Last night, first time in my life, I tried launch control after reading guides on the internet. However, It did not go as expected.....
Lucky, I got two or three times success I assume. When I say success, I judge it purely by before launch, I was able to have the rev stabled at 3000 rpm before release the brake..
But for a few times:
1. I cannot have the rev pass 2000 rpm like what happened to the D mode.
2. Or I also had a few times that the rev is not limited at all, I can rev it all the way to 6K rpm if I like but no feeling of power in at all, same like you put the gear in N and try to accelarate..
The launch control process I followed was:
1. Fully stop the car and hold the brake
2. Change to S mode
3. Change ACC to sport
4. turn off the ESP
5. push accelarate while hold brake to let rev reach about 3000 rpm
6. release the brake while push the accelarate as deep as possible at the same time..
So anyone could share me some idea about what happened to cause those situations. Or maybe something wrong with my car =.=!!
I will ask the question later this afternoon as well when I pick up the car...
Thanks in advance!
2. Change to S mode
4. turn off the ESP
Thanks in advance!
