Intercooler question to experts
  • Intercooler question to experts
    This is a new thing I got the know while reading about A45 AMG which has a water cooled intercooler. It is not a air to air intercooler like we have but air to water intercooler. I heard it helps to reduce turbo lag and boost drop through intercooler and more efficient. Does any one know this is true and has any one done something smiler as a conversion to normal car.?
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Its a completely different intercooler setup - the old Toyota Celica GT4's used to use water to air intercoolers too.
    Reduced turbo lag and boost drop comes from a much shorter network of pipes (normally the water to air intercoolers are located quite close to the turbo), whereas traditional air to air intercoolers have a much longer network of pipes as the intercooler is located at the front of the car.
      Early Subaru Legacy turbo had water/air intercooler.
      77tsi Polo has water/air intercooler too.
      IIRC, the Legacy had a separate radiator & water pump for the "turbo water".
      The Polo uses the same cooling water as the engine / transmiision / oil cooler (not sure how many heat exchangers they've got in the system but you get the concept?).
      I think it's under the heatshield
      The Subaru version was very efficient & relatively compact.
      I'm not so sure about the efficiency of the 77tsi version as I assume it's running at about 95c all the time because it's cooling the engine as well?
      If you google images "water air intercooler" you will see plenty of examples
        does anyone know if water (water only) injection would have a similar effect. i'm thinking about installing it on the s3 but don't want to run meth and change the timing as it sounds a bit dangerous...
          Yes. Thanks, I get some idea about it. I think polo 77tsi has so small engine and a intercooler so cooling through already available radiator and pump for engine cooling may be cost efficient?
          But for bigger engine may need a separate water pump + radiator + new water air intercooler. Anyway this should bring more better efficiency because A45 using it with 29 PSI boost. But conversion of a standard type intercooler system to a watercool type may be prohibitively expensive.
            I've run water only (serco or sparco??) injection back in the 80s on a falcon & a capri - both Naturally aspirated. On the Falcon it was brilliant. I could run big timing & the fuel economy on a trip was amazing - 40mpg! On the Capri it didn't seem to do a thing but the Capri was always a disapointment so maybe that's to be expected.
            I'm not quite sure what you mean by "the same thing" but water only injection will cool the incoming charge & clean the intake, cylinders & (a little bit) exhaust. It will also slow the flame front & help control detonation & help if your fuel is a bit stale.
            If I could get a decent plug'n play kit at a good price I'd do it tomorrow.
              77tsi would be cost, packaging & weight.
              I don't a water/air intercooler would be OTT expensive but it would require a lot of thought for possibly not a lot of gain. It's not a new thing.
                I can't see coolant being able to remove any heat from the intake air. It's going to be over 80 degrees easily!
                Water to air has a separate water system.
                  Also reduced lag because the water/air IC is smaller than an air/air IC
                  Not including hers...
                    It's all about the ability to exchange heat - you can have good & bad in both systems. You can heatsoak an air / air version, but they recover well. If you heatsoak a water / air then they take a long time to recover.
                    best Water / Air version i had was on my Cayman S Turbo. It used a big heat exchanger, massive water pump & had 38 litres coolant capacity. That sucker could really control intake temps.
                    On our APR Supercharger kits for the RS4 / S5 / RS%, they are all running W/A for packaging purposes - ultimately it's up to coolant capacity & the exchanger cores & radiator on how well they work. The S5 is better than the RS4 as you can fit way more coolant in the system.
                      Lotus were using water-to-air intercoolers for a long time in Esprit models. I think they stopped with the V8.
                      Anyway, the only down side of that system was the pump. The rest was fantastic, probably why they use them in high-end model.
