Hey all, I have a Cordoba Booster and MC, but the MC only has 2 outlets. Anyone know if I a 4 outlet Cordoba MC is a straight swap?
I.e, will it fit up to the brake booster, the bolt holes look to stay the same across most MCs but what abt the rod connection (booster > MC)?
Don't want to have to replace the booster as well if I can help it!
yes, it should be. the 2 outlet one is for abs cars, hte 4 is for non abs. straight swap.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Was thinking of drilling and tapping my 2 outlet MC..
The casting is structured as if it was made for 4 outlets, but only 2 were drilled in the factory.
I figured I could remove the internals then drill and tap it to the required thread.
Does anyone have any experience with this? Kinda hesitant to mess with it if it is potentially dangerous..
so you only need 1 wire from that group of 3 to actually trigger the brake lights?
If you could provide a little more info pete that would be tops.
I will be doing this swap in next week or so, Got the bigger drums, Cordoba Booster, and a Audi Master Cylinder (i think)
Due to a really bad brake booster on my Mk1 Cabby, I've gotten my hands on a Mk3 brake booster and master cylinder for this mod...
Quick question though, as the Mk3 was 4 wheel disc, and the Mk1 is 2x disc and 2x drum, will I need a restrictor of some sort in the rear brake lines???
THanks guys...
Update:
Looks like I have another issue now...
The Mk3 I salvaged the parts from, only had 2 outlets on the master cylinder...
Now I need to chase up a couple of t-pieces...
'90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine... '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
'07 Eos 2.0 TFSI - Project Eos...
