The yokes on that bar across the back of the engine bay are the same casting as the one on the end of the booster, they're just machined differently.
One end is M8 with a left hand thread and the other is M8 with a right hand thread as you would expect from a tie rod. The left handed one is designated by a groove machined into the collar.
Both of these ends could be drilled and tapped to M10 and be used to convert more boosters.
The hole across the end for the pin is the same in all cases - 10mm diameter.
Here's a tip for you youngsters at home - To measure the diameter of a hole use the shank of a drill bit as a gauge.
