its running at idle is good but misses for a short time after being reved
it has new leads new spark plugs new cap and rotor button
its less noticeable when you screw out the idle air by pass screw on the throttle body.
its has new injectors but there for a benz but the plugs dont look fuel fowled
im using the 8v fuel metering head but not reving very high so not running out of fuel
i have a fuel pressure gauge off the top of one of the injector lines it fluctuate a fair bit after reving i suspect the fuel accumulator is at fault anyone got one i cau use to test with?
other thoughts?
other thoughts?
