You might be able to tell me Mark, regarding the immobiliser issue
(copy from my thread on vwvortex)
from what i've read on Ross-tech the immobiliser (Immo 3) wont let a new used ecu (ECU#2) just plug in and run as it needs to be coded to the car. However if i understand the instructions correctly i need both the 7digit SKC from both the Current ecu (ECU#1) in the car and the SKC from ECU#2 i'm intending on putting into the car.
Thus the problem, the ECU i'm looking at purchasing is from a wreckers and as such has no car attached to it anymore and no way to pull the SKC that i know of. Does this mean that this ECU is effectively useless for me and essentially anybody that might purchase it?
Another issue i've found on ross - tech:
Does this mean that effectivally unless you can get all of these 4 pieces of information for both of the ecu's then the new used ecu is useless unless the immobiliser is disabled? Is there any way to do this without the car, ie if i just plug in the new used ecu can Vag Tacho pull the required 4 pieces of information from the new ecu?
Arghhh damnn VW and making things difficult
i now remember why i gave up on boosting the vr6 the first time and just bought a GTR instead! This time i'm more determined though!
How does the 7 digit PIN/SKC work?
Check this page for the 7-digit PIN/SKC dialog in VAG-COM:
Ross-Tech: VAG-COM Tour: 7-digit PIN/SKC
You must enter the following information:
7-digit SKC that the dealer retrieved for your exact Immobilizer ID Number.
Date on which the 7-digit SKC was RETRIEVED BY THE DEALER.
Workshop Code (WSC) for the dealer that retrieved the SKC.
Importer Number for the dealer that retrieved the SKC.
The 7-digit SKC is useless without the other three items.
