fifth injector
  • fifth injector
    i was on the web and found a thread in reference to installing a fifth injector, it was positioned before the throttle body butterfly it would require a hole drilled enough for the injector rubber gromit to bed into, an injector a conector plug and section of the loom has anyone seen or done this?
    wouldn`t that be a 7th injector for you mate? You could prob set that up with the microtech on your car
      I have heard of the existing cold start injector (K-jet) being incorporated to the super charging switch. So when you hit the switch the fith injector becomes active
        the thread was found on a peugeot 205gti forum in relation to a fifth injector setup on the throttle body pic attached would be good with a turbo setup on a four cylinder 2.0 golf engine with microtech
          I used the cold start injector on my MK1 to get more fuel. Using a box called a map fueller. Pretty crude but it worked a treat. Has a vac switch built in so it only injected when under load.
          The box could drive 2 injectors if required and you would drill them into the back of the inlet manifold, firing between 1 and 2, 3 and 4 for best distribution of the fuel.
          Reasonably easy to set up with a lambda reader to monitor the mixture. You could do it on the road easy enough. 6 or 7 settings based on revs, you could increase the duty cycle of the injector up to flat out to get the fuel you needed.
          With a pressure switch you could use it with a turbo too.
          PS looking for a link now.
          LINK found
          Home of the World’s most advanced Water Methanol Injection systems Aquamist Direct Full Line Choose  Latest News The Forum has re-opened! – click here We are experiencing shipping delay issues from our international shippers including Fedex, TNT (Fedex), DHL, and UPS.  We are unable to deal with them on your behalf and have no additional […]
