Hi All,
I have been searching through these pages to research the difference between the 96Kw & 128Kw 2.5 TDI Transporter vans. I am currently looking at buying a '06 96Kw 2.5ltr TDI Transporter as a upgrade for the family as the kids get bigger. I have reading all about the different model variants (which is a few) and can't seem to find any reference to the output difference between the two motors. From what I can see they are the same motor both 2.5ltr TDI but one has a higher output rating than the other.
Is the differnce an actual mechanical difference in the motor/driveline or is it all in the ECU/tunning side. If it is in the ECU does anyone know what is required to upgrade the 96kw to a 128Kw or more to the point can it be done?. If so who/where and rough cost.
Has anyone out there driven both that could give me an opinion of the difference, the reason I ask is it will be moving 2 Adults and 7 kids around the countryside with all the usual gear, from all the reading I have done the VW van is the way to go but I am still trying to find one to test drive.
Any and all knowledge or opinions would be greatly appreciated as I know very little about the VW side of the fence as I have not previously owned one.
Kind Regards
Vwnewby.
Kind Regards
Vwnewby.
