A set of mild cams (they are about $500-600 Aus)
Chip $1k ( I know its over priced but I dont set these prices!)
This will give you the most bang for buck then your better off pulling engine apart and
83mm Pistons , raised compression , over size valves , titanium retainers and collets , schrik manifold , extractors , machined throttle body .
This will probably cost ya around $7k to do locally and probably yield same power results as above .
Extractors are a waste until you start doing serious work . chip and a mild set of cams dont flow much more than stock so you dont need them . The exhaust manifold is a really good design so until your flowing there aint much point .
