at the risk of sounding stupid and getting flamed, I would like to throw my chipping theory out in the air anyway.
when overclocking computer parts i.e CPU's, graphic cards, the extra power generates more heat, so you also have to invest in a better cooling system. Once you get the temperatures to acceptable levels everything is normally ok.
a really good cooling system, is particualy important when you attempt to overclock the latest, fastest, and most expensive computer parts.
but if you get a computer part which dosn't have the greatest speeds, overclocking is generally as simple as changing the settings to a higher speed, This is because computer manufacturers simply underclock the same product to target different market segments.
I was wondering if car manufacturers do the same thing?
alot of times when a car is released, a more powerful model of the same car is also released, normaly called a sports edition or something, which seems exactly the same, except it has fancey seats, spoilers, rims, and more power.
do you think car manufactuers just change fuel delivery, turbo, injection timing settings, to meet different market segments?
can buying the lower model car and then chipping/rempapping it to the higher model be a simple care free affair? and end up being exactly the same as the higher model?
just to note, I've already brought the higher model of my particular car, so too late for me if true
and just incase its not true, I'll finish with a funny little emote
