Stu, you could use the eng you have now I'm pretty sure. You'd just have to upgrade to a different throttle body (say off a 2.0 EFI] Your 1.8 is already injected.
Supercharged mk1
I had the alternator undeneath. I can't remeber why I did it that way around, maybe I had troubles fitting the supercharger down lower. If you can make it work down low it would be better because it is a big heavy thing to have up high. I had a small intercooler up in front of the radiator. It was off a tdi range rover of all things. Did the job though.Originally posted by thestu View Postthats nuts! that what i was saying to dad i could just wire the switch up under the dash so that if there were cops i would just flick it off
how long did it take you to do? did you move the alternator under it? i was thinking of doing the opposite...and having the sc under the alternator...so its at least a lilbit hidden...but i think im going to have to get a 2.0lt with a computer because the k-jet gets in the way massively! is there a small intercooler tucked up the front on the right?
oh yeh i forgot about thatOriginally posted by Jarred View PostStu, you could use the eng you have now I'm pretty sure. You'd just have to upgrade to a different throttle body (say off a 2.0 EFI] Your 1.8 is already injected.
are the intake holes the same size as a mk3 motor? the heads must be close if not the same...except for the amount of vavles!
yeh i want to have it down low because i'm not really meant to have an sc until im 22Originally posted by Grunmk1 View PostI had the alternator undeneath. I can't remeber why I did it that way around, maybe I had troubles fitting the supercharger down lower. If you can make it work down low it would be better because it is a big heavy thing to have up high. I had a small intercooler up in front of the radiator. It was off a tdi range rover of all things. Did the job though.
yeh i have a small intercooler here guess that will do the trick
cOol I reckon I could do this to my 80cc once I get the fuel line fixed
Though Im not sure the auto box would take it lol.
Audi B4 80 Q V6'94 Race Car !! KEGGED
Audi B4 80 V6 Avant'94 Only one in the country that I know of !!! KEGGED
Subaru Forester XT'06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
--VW Bora V6 4mo'01 Gone
K-Jet injectors and electronic injectors are very different things.Originally posted by Jarred View PostStu, you could use the eng you have now I'm pretty sure. You'd just have to upgrade to a different throttle body (say off a 2.0 EFI] Your 1.8 is already injected.
MK 3 electronic injectors are in the manifold and protrude into the head through a wierd key hole shaped inlet port.
MK2 K-Jet injectors are in the head itself.
I have heard tell of people using electronic injectors in the K-Jet head but I believe this requires machining of the head itself or custom injector holders.
Pete79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
oh ok.Originally posted by Peter Jones View PostK-Jet injectors and electronic injectors are very different things.
Pete
so would i be better off sealing up the injector holes i have atm and then machining the head to fit the mk3 manifold? or could i make up a fuel rail with some 330cc injectors and then fit this to either the manifold or drill and tap the existing head...
or just run ITBs...and a custom manifoldLast edited by thestu; 27-11-2008, 02:05 PM."The Stu likes this"
You should be aiming to hit the back of the valve with the fuel spray from the injector. Each of the MK2 and MK3 systems are designed to do just that. So the stock injector position for each type of head is the ideal.
You'll still need to put the injectors somewhere with ITBs.
If I were you I'd do a bit more research about the K-Jet fuel enrichment setup used on the turbo Audis via a manifold pressure feedback circuit into the WUR.
7? MK1 Caddy
12 Amarok
Ok i sorta understand that ha ha. So your saying just stick with the setup i have and find out what i need 2 do 2 improve or modify what i have?Originally posted by Peter Jones View PostYou should be aiming to hit the back of the valve with the fuel spray from the injector. Each of the MK2 and MK3 systems are designed to do just that. So the stock injector position for each type of head is the ideal.
Pete"The Stu likes this"
I have heard of Kjet injector seals modified to fit electronic injectors, it may have been the ports that the plastic injector inserts sit in that were modified to suit plastic inserts for electronic injectors.
That way you retain the factory injection position.
mk2 GTi 16v
Corrado G60
Also I would like to go Kjet turbo on the 16v one day, just to be oldschool.
There are lots of old Kjet turbo cars that you could use parts from. The Ferrari F40 was a Kjet Turbo
Another option would be a blow through carburettor set up (probably mentioned already). The original Lotus Esprit Turbo used twin Dellorto's being blown through.
mk2 GTi 16v
Corrado G60
how do you mention my 2 favoritest cars o all time in the same post??Originally posted by ausgolfer View PostAlso I would like to go Kjet turbo on the 16v one day, just to be oldschool.
the esprit turbo was brilliant aswell - back in the 70's, 225hp from a 1.9 inline 4, in the perrrrrrfect body. gives me those man feelings... sheesh.
i do agree though, plenty of k-jet forced induction production cars were made, and its a matter of adapting the system to your needs i suppose.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Porsche had turbo cars on K jet too dude. And possibly ovlov?Originally posted by Jarred View Postyeah and finding the parts...
I mean how often do you see a Ferrari F4 at a wreckers?
check this out
a neat video of k-jet in action
a list of some cars and their injection systems:
fuel injector rebuilding,fuel injector servicing, wholesale fuel injector supply to automotive service centers,and repair facilities around the nation
looks like some saabs, earlier volvo 240's, lots of dubs, lots of porsche had k-jet.Last edited by gldgti; 27-11-2008, 08:41 PM.'07 Touareg V6 TDI with air suspension
'99 A4 Quattro 1.8T
Thought the 930 was K jet..
PORSCHE 930 SERIES 6 1979-78 3299CC, with TURBO K-JETRONIC
