G-8VXWWTRHPN JH code k-jet 1.8lt 8v turbo setup - VWWatercooled Australia
  • JH code k-jet 1.8lt 8v turbo setup
    has anyone doen this in aust, what is needed???
    wabit
    My mate has a bolt on manifold and turbo setup to bolt onto an 8v Motor. I believe it uses the Turbo from a Golf TDI. He will sell for $1000.
      Have a read & look through this.
      Ton's of info on turboing CIS injected cars
      Some of my parts are here & more to come for my turbo 8v daily driver in the build.
      Basically
      - Volvo 240T(didn't get them in Aust. but can be found on ebay & vw
      vortex classifieds) will require modified fuel lines as they positioned
      differently on the fuel distributor head
      - Audi 5000T Warm up regulator or Volvo 240T Warm up reg (same as above)
      - Distributor vacuum retard canistor or MSD boost timing master to retard the
      igniton as it comes on boost.
      - Exhaust manifold incl at least a 2.25-2.5" exhaust system,turbo of your
      choice(recommend T3 incl. oil line supply & drain into the sump. Water
      cooled turbo's not really needed but optional, just more pipes/hoses!),
      intercooler(not really needed for apllications up to 6-8psi but I would fit
      one anyway) & piping/misc clamps, gaskets, fitting's etc.
      This setup should see approx 170hp+ on a standard 1.8 8v running 8-10psi
      Tim
        Some early golf dissys have an advance and a retard on them.
          Hey Wabit i have performed such a conversion on my MK2 1.8 8v GTI, its not easy as far as tuning goes that was my biggest problem. I used a
          *wrx sti vf22roller bearing turbo
          *3" mandrel bent stainless exhaust
          *custom mild steel manifold using 1 1/4" steam pipe bends
          *800mm wide intercooler with 2" stainless plumbing
          *MK1 GTI inlet manifold with a MK2 throttle body
          Originally i recurved the dissy with retard on boost and a hobbs pressure switch to activate a fifth injector under boost, i had difficulty sourcing a larger warm up regulator and the engine leaned out in the top end revs. This setup saw 105kw atw on 10 psi, With standard internals and 10:1 compression. In the search for more power and frustrated i took off all the factory injection and fitted an EMS computer with EVO 5 injectors, with the dissy locked and an ignition module fitted the power jumped to 138 kw atw on 14 psi... I would recommend aftermarket injection
          Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
          Mk1 twin eng twin turb
          scirocco gti 2.1l 16v turb 6spd
          Audi A4 B5 1.8t
            just found this on ebay... this guy sounds like he knows wat hes doing!
              Any good pics of your engines with the turbo setups ?
              sigpic MK2 GTI G60
                All of them did.
