I thought I'd kick off a new thread to capture this info. There's a few little gems of wisdom dotted around the forums but it's hard to join all the dots at the moment.
Here's my first contribution. What we're going to do here is in preparation to to put a 2.0L (2E motor) bottom end into a MK1.
Most MK3s , the source of this motor, have power steering and air conditioning pumps, neither of which are usually required in a Mk 1. To do this they run a ribbed belt called the serpentine belt and a V belt. Both belts are driven off the Crankshaft. The serpentine belt drives the Alternator and the A/C compressor. The V Belt drives the Water Pump and the power steering pump.
Now, to put a MK3 motor into a MK1 you could just use all the MK1 v belt pulleys and alternator. (The water pump may have to be changed too.). The advantage of keeping a serpentine belt setup are many.
Remove these bits.
We're going to need one of these to drive the water pump. It's a water pump pulley off a VR6 Mk 3 Golf. I got this one from GAP http://www.germanautoparts.com/Volks.../Cooling/162/4
First of all I'm looking for alignment of this pulley to the existing belt. As you can see in the next few shots it works out to bee a little too far inset. I'm going to need to make a spacer.
- Easy to Change Belt
- 90 Amp alternator (instead of 35 or 50)
- Automatic tensioner
- More robust mounting mechanism for alternator
- Etc
Remove these bits.
