Wreck to Race.
  • Good luck Pete!
    • Cheers Jarred!.
      I've set my laptimer to tweet laptimes as I go round. (Isn't technology amazing?)
      If you're interested, the username to follow on Twitter is team_pragmatic
      7? MK1 Caddy
      79 B1 Passat Dasher Project
      12 Amarok
      • Pete, its fantastic to see you build this mk1 from what it was to what it is now and following your progress with the races. It certainly an inspiration for me to get a track mk1 built one day.
        Good luck with the race mate.
        2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
        1986 SAAB 900 Turbo 16 S
        • Great day out the Island today, managed to better my previous best time by 5 seconds and pulled a time of 2:08:8257.
          Car's going well, minor fuel surge issue during one lap, probably due to heat, otherwise it was on song all day.
          Just working on some video now.
          7? MK1 Caddy
          12 Amarok
          • woohoo! good work! 5 seconds is a fair effort!
            • 5 seconds? Bloody hell!
              • Here's the video of the round 4 flying laps. Lap 1 is the fastest of the day.
                I think I can knock at least another second off that if I get a bit braver in turn 1.
                Previously I'd brake and change down to 4th. During yesterdays runs I figured out how to get through there in 5th with sufficient RPMs but I think I'm braking too hard and could go in faster.
                I'm having a few issues with the GPS data for the other rounds, I'll try and upload some more videos tonight. Be sure to watch them in HD with the volume turned up
                7? MK1 Caddy
                12 Amarok
                • In the above video during lap 3 I started having an issue with fuel surge at WOT which is why my speed drops off in turn 1 at the start of lap 3.
                  Here's the footage of round 5. The fuel issue sorted itself out, I suspect either heat or the filter prior to the pump.
                  7? MK1 Caddy
                  12 Amarok
                  • Way to go, Pete! I watched your first vid this morning.. Good stuff.
                    A bit of oversteer in a FWD is a good sign, means your car is pretty neutral.. How does it feel??
                    I see you started to have a bit more of a dig with that Mini held a carrot out infront of you..
                    • It's actually quite neutral, the diff helps a lot with that.
                      7? MK1 Caddy
                      12 Amarok
                      • Nice! And that's the wavetrack, correct?
                        I've been thinking i'll probably get a Peloquin (when I do finally change the diff centre), but i'm not 100% sure, yet.
                        • Yep, it's a wavetrac. Changes the way the car handles completely. Rather than causing understeer you can use the throttle to pull you straight.
                          I found it to help with braking too, haven't quite figured out why though. Makes it harder to lock just one wheel when the weight's off it.
                          Also it doesn't free wheel like some LSDs when you button off so if you have to lift off the throttle mid corner to avoid an incident things don't so funky as they do with an open diff or a plate style diff.
                          7? MK1 Caddy
                          12 Amarok
                          • Didn't you buy both brands of diffs for comparison? Have you tried the Peloquin yet?
                            Great video by the way. You must be having a bucket load of fun out there!
                            2010 Tiguan 125TSI
                            2004 Polo Match
                            1976 White MkI Golf
                            • Haven't tried the peloquin yet, just haven't been able to organise getting the other box built up. Every time I've got enough cash to do it I end up having to have the wavetrac equipped box pulled apart for some unrelated fault.
                              First time I had to replace a cracked input shaft, second time I got it stuck in third gear. Each time I had to put my spare close ratio box into the car while the wavtrac box was being repaired which of course also prevented me from getting a diff put in it.
                              Mind you with all the practice I've had I can swap out a MK1 gearbox in 2 hours now!
                              7? MK1 Caddy
                              12 Amarok
                              • Bit out of sequence, but here's white at SEDF.
                                7? MK1 Caddy
                                12 Amarok
