Originally posted by quozl
View Post
VW racecar R32-Some advice!
ECU code is different, not sure what MAF they are using, the US has a different MAF to Australia but I have no idea what the UK / Euro cars run. Other than that internally they should be identical.
Cheers Al
Originally posted by JVLR32 View PostWell i finally found a R32 o4 motor gearbox 44 thou miles on clock! should be here in March cant wait! thanks for everyones help. Does any body know if Uk is different to Aust spec R32 motors?mk4 the mods begin for round 2 hahahha
Yep i will be using the standard Ecu! Personally i think this engines run faultless with wat they have.I will run a APR chip set up ...2 wheel drive. I run the same chip in my 04 R32 unbelievable......Surely the Uk specy should be a more hypo motor!
Originally posted by JVLR32 View PostYep i will be using the standard Ecu! Personally i think this engines run faultless with wat they have.I will run a APR chip set up ...2 wheel drive. I run the same chip in my 04 R32 unbelievable......Surely the Uk specy should be a more hypo motor!
whats this going in? somthing lightmk4 the mods begin for round 2 hahahha
Originally posted by WABIT View PostZOMG!!! $5K FOR A CRATE MOTOR.... I COULD HAVE HAD A MK1 R32!!! and thats no word of a lie!!! i thought they were over 6-7g's
wabit
Originally posted by JVLR32 View Postgood stuff. Boys still trying to sell a R32 04!
I'm sure there would be plenty of takers for the parts you didn't need given that many of them are bolt-on for other VAG cars, and you'll be assured that the engine, transmission, wiring loom etc are all in good condition and that you've got all the parts you would ever need.
Failing that - wasn't there a written-off R32 in a Pickles auction recently? That might still be floating around the country somewhere.
Failing that still, if you're not afraid of a bit more work and don't mind looking at a VAG 'cousin', there is a written-off Porsche 997 GT3 coming up for auction tomorrow at Pickles. That 3.6L flat 6 would be perfect...
