Originally posted by AUC-05L
View Post
The Mk1 ABF Project
Originally posted by cartertronic View Post
Mounts on top of strut
OR
Mounts on side of strut tower
Good job on the project too.
Good planning & preparation makes all the difference with big projects & conversions.
Keep it up & will be keeping an eye on this project.
Originally posted by golfworx View PostI'd be more inclined to go for the 2nd one as it actually ties into the body which is what proper stress bars are all about, where as the 1st one only ties the shocker pistons together & they can still move about on there rubber mounts.
That's a really good point about the shockers flexing against the bushings. That brace actually has a slight bend in it as well, which could be prone to a little flex.
My only concern with the second one was where it attached to the towers. I.e. Whether the metal on the towers was thick enough not to flex when the brace starts pushing it around...
Originally posted by golfworx View PostHe posted the info up on the 3rd page about freight costs
cartertronic- is this the mob you ended up going with http://www.havas.co.uk/?Last edited by AUC-05L; 28-04-2010, 08:36 PM.2008 POLO GTI - SOLD
2005 MkV Golf GTI - couldn't resist
Originally posted by cartertronic View PostThat's a really good point about the shockers flexing against the bushings.
Pete79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Originally posted by Peter Jones View PostFirst type is pretty pointless really. There's plenty of metal in those towers to support option 2 although I'd be putting a plate on the inside of the tower. Something with a diagonal brace would be better again.
Pete
i only just read your thread simon! forgot you changed your screen name
good stuff man!!!
if ya need a hand i've done my share of mk1's in my short life"The Stu likes this"
Anything with a bend in it is pointless if you ask me. As soon as you bend them, you've lost the strength.
It won't stop chassis flex because of the rubber mounts either.
Think about what sideways forces are you trying to control here. There's not a lot of horizontal thrust vectors at play at the top of the shock itself.
Even option 2 is dubious. What does it matter if the towers move sideways? The suspension pivots from further forward underneath the car.
Controlling the chassis flex should lead to some improvements in weight transfer as you throw the car from side to side, hopefully that pays off in more predictable handing.
Tying the rear towers together should stiffen the back up a bit but without the diagonal there's still potential for parallelogram distortion of the rear box area.
The distortion you're trying to control can only come from the vertical motion of the shocks pushing up harder on one side than the other.
Shiney shock tower braces are pretty cool though.
7? MK1 Caddy
12 Amarok
Originally posted by Peter Jones View PostBending isn't the issue though here. All this style of bar does is tie the tops of the shocks together. Unlike the front, the position of the top of the shocks doesn't affect the tracking geometry.
Pete
You also are trying to stop the shock towers pushing together. This happens through cornering and under brakes. Tieing the strust towers together prevents this and makes the car point far better and stops the front wallowing and wandering under hard braking. It makes it more stable and more predictable.
The year before last i made a tubular front strut brace for my mate's MK1 escort track car (bit of a weapon- 200hp Pinto engine, sierra 5 speed, mexico guards, half cage.. The whole nine yards). You wouldn't believe the difference it made to thr front end.. It was like night and day. And that was without tieing it in to the firewall.
On the back though? Even if the towers do get closer to each other it's not going to affect the rear tracking geometry, just the way the springs work and mess with the weight transfer as the twisting coach work is providing it's own spring rate.
Generally though, getting the car as stiff as possible is the way to go.
If you wanted to control rear camber changes due to corner loading you'd do it more like this.
7? MK1 Caddy
12 Amarok
Originally posted by Peter Jones View PostAbsolutely agree on the front towers, they bend inwards under load and the suspension geometry changes causing undesirable camber changes.
Rear doesn't matter much really, if you're doing it right you've got one wheel in the air anyway79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
12 Amarok
