Hi all, I have red a bit of info on here regarding the G60 brake upgrade for MkI golfs, with I believe 280mm discs, but am new to the vw stuff...
1) what actually is the G60?
2) are they actually bolt straight up, or just very easy to swap
3) I have also red about 305mm(?) upgrade, what car are they off, vented? and straight swap? or just easy to swap?
4) what size wheels are required for the larger 300ish mm discs?
I currently have 15in rims, and from what i have red, they fit the 280mm discs... I will also be upgrading the brake lines and the res/master cylinder etc...
Also, is there many drum - disc conversions around and/or is it easy to do? (for the rears)
Cheers...
Ash
Cheers...
Ash
