G-8VXWWTRHPN suitable oil for an older golf. - VWWatercooled Australia
  • suitable oil for an older golf.
    Checked my oil this morning and it's towards low but I don't have any suitable for older cars. Only magnatec and I don't think my golf will enjoy consuming that!
    I don't have much idea on what to buy so could someone please advise me on which is best ... 1994 model.
    Also noticed that I need to top up the coolant! Is coolant pretty much standard for all types of cars?
    Money money money
    15w40 is what i use for my '91 mk2 id assume its something similar... just check your manual it will tell you.
    2x Caddy, 1x Ducato
      Money money money
      Nothing wrong with Magnatec. I reckon the grade is 10-40.
        I have been running Fuchs 10w40 fully synthetic in my VR6 with no issues except that it tends to burn a bit off. Am currently running Castrol GTX2 20w50 to see if it likes that a little better being such a hot running engine.
        It was down to a choice of that or Magnatec after much discussion on here.
          I did some research and read that they make oil for older cars, over 75k, synthetic. Browsed quite a few different pages about it and found a link about it to WC back in 2002...
          http://forums.vwvortex.com/zerothread?id=582952
          Most were for it and had no problems switching over. Are most of you using synthetic oil? Mobli 1 had a fair amount of good reviews.
          I guess one can only try a few and see which runs better in the car. I plan on making a visit to get some today, so I will let everyone know how it goes!
          I'm sure there are newbies out there like myself ... not much idea on how cars run but willing to learn. Found this site on oils...
          http://www.carbibles.com/engineoil_bible.html
            You are wasting your money with a synthetic oil in that car.
            Castrol or similar will be fine and a 5th of the price.
              To eat my own words I ended up getting magnatec. Much in my price range and my partner recommended it. He's been using it in his magna for a few years now.
              So much knowledge to gain about cars and how they work!
                I'm interested to learn why you say this, your reasons behind it.
                  Simply that engine was not designed for synthetic and now it is worn, synthetic is too thin. A good mineral oil burns less, makes the motor run more smoothly and costs less, for that motor.
                    makes sense ...
                      As for the G12 VW coolant, I wouldn't be using anything else in your car...
                      RIP Ruby Thunder (1994 VR6), now driving the GF's MK IV 1.6
                        Im guna change my oil tomorow.
                        Do brands matter?
                        And what oil filter do you recomend?
                        MK1 GLS 3door
                        A4 B7 2.0T
                          Stock filter. Bad things happen with aftermarket ones.
                            ...And for oil brands?
                            I should probably do this before I get my licence back...same oil (not even refilled) since....march
                              Which means there is probably no oil in it...
                              I'm running Castrol GTX2. Seems to last better than the fully synthetic Fuchs I was running... and it's much cheaper.
                              10w40 vs 20w50 which means it works better in a hotter engine.
