Repco full synthetic 5W-30
  • Repco full synthetic 5W-30
    On special this we for $45/5L. Anyone know if it meets 504/507? Supplied by?
    If that's a Repco branded oil, I seriously doubt that.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      Apparently brewed by Penrite.
      And no, I highly doubt it's 504/507 spec.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        I use Castrol EDGE - and the last time I saw the workshop here on the Gold Coast - they use it there too - I get it from Super Cheap - waited till it was on special for $35 - then used $10 of my Club Rewards to bring it down to $25. BARGAIN
        NOW: 2018 MY19 Kodiaq Luxury and Tech Packs: 132kW Petrol 7DSG Sunroof and Ivory Leather
        HISTORY: 2012 Fabia RS (FOR SALE) ; 2013 Fabia RS (SOLD); 2015 Octavia RS 135TDI (SOLD)
          Both the Repco and Castrol Edge oils don't say "low SAPS" - hence may not be the best choice for late model turbo engines...
            Technical Data Sheet Link
            http://www.tds.castrol.com.au/pdf%5C...71_2011_09.pdf
              Not sure that the professional version is the same as the garden variety Edge 5w-30 as the TDS is different.
              2.0 TFSI Stage 2 Tune by DriverMotorsport
                That's the wrong TDS indeed - the correct one is here:
                Our purpose is to deliver energy to the world, today and tomorrow
                This is the part that needs to be read/understood:
                Originally posted by Castrol Edge
                PERFORMANCE LEVELS
                Castrol EDGE 5W-30 A3/B4 surpasses a wide range of specifications and has numerous
                manufacturer approvals and is suitable where the following requirements are called for:
                • American Petroleum Institute (API) Service Classifications
                • Petrol : SL*, (SJ, SH and all superseded classifications):
                • Diesel : CF
                • CEA A3/B4, High performance shear stable petrol/diesel engine oil
                • BMW Longlife – 01
                • VW 502 00/ 505 00
                • MB Approval 229.3, 229.5
                * Passes all engine test performance requirements of API SN and SM but exceeds Phosphorus limits of those classifications.
                  Originally posted by BrashDaniels View Post
                  You can't buy the Castrol Professional line at retailers.
                  The one at Supercheap is Castrol Edge Sport. It's 502/505 which is fine in many instances (I run 502.00 in my car on 7500km change intervals).
                  I think the OP has a diesel with DPF so 502/505 would be verboten.
                  To the OP: The cheapest you'll get 504/507 for is ~$65 for Penrite Enviro+ 5w-30. Maybe a bit cheaper on a 20% off sale but often the stores seem to hide the good stuff on those days (or it sells out quick).
                  It would help if you told people what engine you had so that the petrol lads don't post petrol based info.
                    it tells you on the back if it APPROVED for VW 504/507. If it doesn't it isn't and you use it at your peril.
                    Look on the Penrite Enviro+ and it says that.
                    NOT the new G5+ or whatever its called as that is a GM approved oil.
                    Supercrap and Autobarn only sell the Penrite VW approved The Castrol Professional III is only available at Dealers for about $93 for 5 L
                    Shell Helix Ultra EXTRA is approved but only for Petrol engines and is 502/505
                    Use the wrong stuff long enough in a diesel and you better put aside $5K for a new DPF when it clogs up with too much crap in it.
                      Just rang them....not for current diesels with DPF.
                        There's a Valvoline SynPower as well as Nulon Euro option now for the current VW/Skoda/Audi engines:
                        Valvoline: Valvoline | Full Synthetic | Engine Oil | Valvoline.com.au
                        XL-III 5W-30
                        Available sizes: 20L, 208L
                        Approvals/Performance Levels
                        SAE 5W-30, ACEA A3/C3, BMW LL 04, MB229.51, MB229.31, VW504.00, VW507.00
                        MXL 5W-30
                        Available sizes: 5L, 208L
                        SAE 5W-30, API SL, CF, ACEA A3/B3/B4, BMW LL 01, VW502.00, VW505.00
                        Nulon:
                        Full Synthetic 5W-30 EURO Engine Oil- Nulon Australia
                        Not sure what these are worth as i don't personally use them. I use LiquiMoly 4200 TopTec and that normally retails for around $90 or so here. I recently ordered 3x 5L bottles from USA for $190 delivered which was a good price.
                          The salesman who wasn't there should have given you a Castrol pamphlet about the correct oil otherwise after a few days of short reads in the bog you will come to the fuels and lubricants section of the manual where it will tell you what to use.
                          So as you wont be further confused ignore the longlife details as only time and distance is used in Australia so it 12 months or 15000k whichever comes first.
                            XL-III 5W-30
                            MXL 5W-30
                            Nulon:
                            IS Nulon now approved as last time I looked it was "Suitable" for VW which is a lot different to "Approved" for VW.
                            Consequently I wont use it.
                            From the link
                            Suitable for use in the following manufacturers
                            •Audi
                            •BMW
                            •Mercedes Benz
                            •Skoda
                            •Volkswagen
                            "Suitable' is vastly different to 'Approved"
                              Appears to be approved now:
                              Full Synthetic 5W-30 EURO Engine Oil - Nulon Products Australia
                              Nulon Full Synthetic 5W-30 EUROPEAN Engine Oil is approved under VW Standard 504.00 and VW Standard 507.00 for Volkswagen, Audi, Skoda and Seat petrol and diesel vehicles within manufacturer warranty periods.
