Help, Penrite 5w30 Enviro+ GF5, not VW approved?
    Originally posted by Hillbilly View Post
    Well mine was done under fixed price 2 weeks ago and they just didn't add the price of the oil on.
    It usually a fixed labour charge plus oils and parts.
    When I was asking prices they wanted to charge $118 for a 5L of oil, when it was $93 in the service dept, so I said I will provide the oil.
    No problem am happy with the subsequent pricing
    Thanks for that Hillbilly,
    it may be up to each dealer but I will go ahead armed with your advice.
    (I notice on the oils site back in 2009 that VW specify NO intermediate oil change till it's done the first 15K which I assume is to have a 'lapping paste' effect for bedding in purposes combined with a bit of high BMEP . I accept that argument since VW have had issues with high oil consumption so will be happy for just this period)
      Enviro+ is normally about $83-89 I buy it when its on special for $65-69
      Currently (14/11/2016) - 5L container of Penrite Enviro+ 5W-30 is $79.99 at Autobarn. Where did you find it on special at $65?
        Usually at Repco or SCA.
          Thanks.
            It is good to know which oils you can use, chances are one of the majors will have something on special.
            SuperCheap
            LiquiMoly for $10.77 per litre
            Liqui Moly Engine Oil - 5W-30, 1 Litre - Supercheap Auto
            Castrol Edge FST is often on special around $55mark, or $68 right now.
            Castrol Edge Diesel DPF Engine Oil - 5W-30, 5 Litre - Supercheap Auto
            Nulon, buy 5litre get 1 free $70
            Nulon Full Synthetic Euro Engine Oil - 5W-30, 5 Litre - Supercheap Auto
            MK4 GTI - Sold
            MK5 Jetta Turbo - Sold
              [QUOTE=JustCruisn;1206685]
              It's now down to $52.49 at Supercheap until the 20th.
              Numerous Mk1 Golf diesels
                Yes I saw that too. See there is always something on sale.
                I might get another bottle but do I really need 15litres of oil in the garage?
                Sent from my LG-D802T using Tapatalk
                MK4 GTI - Sold
                  Repco were selling 20L drums for $130 last weekend (same date as your post)
                  I grabbed one, 4 oil changes for a little less than the price of 2 ($6.5 per litre)
                    I went down this morning & bought a couple, now I have almost 15 litres.
                    I can see why people have trouble with buying the right oil. Castrol have two products called Edge FST in 5W-30. I was told by the assistant, after first looking at one that had no reference to VW 507[ but did say, not suitable for vehicles with a DPF] that they have probably just changed the label on the front. The price tag also said $52.49.
                    I was rescued by a switched on female store manager, who I had spoken to on the phone earlier who was able to sort it.
                      The correct Castrol has a different shape bottle to the others.
                      MK4 GTI - Sold
                        This one Castrol Edge Diesel DPF Engine Oil - 5W-30, 5 Litre - Supercheap Auto
                        It doesnt hurt to use a higher spec oil but it does if you use a lower spec one
                        Both of mine have been on Penrite Enviro+ since first service and dont use any oil and run fine
                        • #27
                          A relevant video about misconceptions of engine oil.
                          Go to 10:30 min mark if you think you know about engine oil.
                          The low down of the video:
                          Approval from VW means the oil recommended meets the minimum quality/standards.
                          There are better oils for your engine that may not have an approval, getting an approval is an option
                          • #28
                            For the sake of maintaining your new car warranty, it is strongly advised that you stick to what the manufacturer recommends in terms of what's been approved.
                            • #29
                              Yep, and when your engine goes south, then go to the media and make a big noise, blaming everything else except yourself.
                              • #30
                                Regardless of whether they are better or not, in your opinion, try telling that to a VW service manager when your engine carks it due to incorrect unapproved oil.
                                The fact that VW approve it is good enough for most of us and if the "better" oils choose not to seek approval means only that they miss out selling to one of the top 3 producers of vehicles in the world. Hardly a sensible business decision methinks.
                                Even Nulon finally got VW approval for some of their oils
                                Incidentally Liqui Moly do have VW approved oils and are recognised as being one of the "better" brand of oils.
