1 of 2
2 of 2
2% Ethanol mandatory in NSW (September)
Ethanol and other additives to petrol
I think that this web-sourced article is referring to much larger %ages than 2%, however....
"Fuel ethers and ethanol are more effective octane components since they deliver higher octane numbers than aromatics and therefore require less volume to deliver the same amount of octane. However, ethanol cannot be utilised without difficulties by the refiners in petrol because of its high water solubility, which effectively prevents its use in the distribution system for petrol. Ethanol has also a high, non-ideal blending vapour pressure which tends to knock off some other, light, low-boiling hydrocarbons from the gasoline blend in order to meet the volatility regulations. Technically, and because of its higher cost, ethanol is not really a viable alternative."
Source: http://www.efoa.org/oxygen.html#4 on 14th May 2007
There's plenty of info on the 'net. Just do a search.
This has the makings of an interesting and ongoing thread so I'm moving it to "Fuels and Lubricants". Dutchaussie....Are you ready to comment??
yep, ive seen a head that was rusted out from ethanol not pretty. This is how i had it explained to me from an engine re-conditioner, remember school science getting water from metho? thats the same with ethanol. It also has a different mixture compared to normal fuel, so on a carbied car the air fuel mix can go right out and the engine can lean right out and... well you know what happens then. I really don't want to touch the stuff.
On newer cars you shouldn't have any issues though as the ecu will handle a lot of those problems except it rusting your head!76 MkI 3 door - daily drive/project - 1.8 5speed
Properties of ethanol
Ethanol is water-soluble and hygroscopic. In other words it dilutes in water and attracts and absorbs any free water or water vapour around it. This probably wouldn't be a problem in a closed fuel system in a car, however it's a bit of a worry in a servo's tanks as they are vented.
2% is 20mL in a litre and this isn't much ethanol by proportion (imagine 4 teaspoons) so I personally can't see much potential for disaster. However as the proportion increases so does the risk.
If my memory serves me correctly Brazil had 100% ethanol Beetles. Obviously the whole fuel system was redesigned to cope with the fuel, however if again my memory serves me correctly there were so many problems that they gave it up.Last edited by Guest; 14-05-2007, 08:48 AM.
Originally posted by brackie View PostIf my memory serves me correctly Brazil had 100% ethanol Beetles. Obviously the whole fuel system was redesigned to cope with the fuel, however if again my memory serves me correctly there were so many problems that they gave it up.
The ECU cannot adjust by itself for ethanol, so the mixture will be wrong.
We will now cut down many hectares of forest to grow crops for ethanol production. I hate half wit greenies
i had no problems over an15k year
i had a mk1 1.8 which i ran as my daily driver did about 15k that year and always filled up with 10% ethonal never had any problems his is only a small time scale thoughowned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
Brackie: They didn't give it up.. the project was started in 1973 after the big oil-crash with sky-rocketing prices. Over the mid-80s and early 90s popularity in E100 cars dropped significantly due to very low oil prices. However, these cars have been resurected in the past few years for two reasons: a) increasing oil prices, and b) because most new cars sold now are dual-fuel (as in E100 and gasoline). In fact, 55% of transport in Brazil is now using fossil-fuel alternatives.
Syncro: With increasing petrol prices, current grain-crops in Australia can provide a minimum of 10% of our fuel usage in Ethanol at approximately 80c per litre. This just means that we've got to reduce our grain exports. Of course there are issues of fuel vs food security if Ethanol production is increased, which is why alot of research is going into alternative crops and biofuel production techniques (mainly Lignocellulosis). Alternative crops (or in fact, feedstocks) which may soon power our cars include waste from households, forestry, farming (crops & animal), etc..
Australia is actually a long way behind most 1st world countries (including the US surprisingly). But its mainly in Europe where the big movers are. Check out Saab's E85 compatible cars which account for a large percentage of the new car market in Sweden.
Anyways.. enough aimless rambling..
Damien
2% is nothing
I use E10 confidently in my mk1 1.8... i would be more worried about mixture issues than rust seeing as the watercooled heads are alloy, and that amount of water (once atomised with the fuel) is negligable compared to natural humidity or driving in the rain. Some of the new Saab engines are built to run on E85, and im not aware of any corrosion issues that have had to be addressed in the design of these.
syncro, i hope to see more ethanol generated from waste derived feedstocks (waste paper, corn stubble, green waste) rather than dedicated crops. I have a friend who is working on a plant being built in WA which hopes to do this.TDI mk1 on the road!!
lets keep the discussion intelligent guys - i don't think arguments about rusting heads (i've never seen a steel or cast iron vw head) really holds up. plus, the chemical nature of alcohols is generally non-detrimental to aluminium alloys.
i too have run E10 in my 1.6 mk1 and havn't had any problems, other than reduced fuel economy (though e10 is damn cheap).
hooray for waste derived fuels!!!'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Originally posted by gldgti View Posti too have run E10 in my 1.6 mk1 and havn't had any problems, other than reduced fuel economy (though e10 is damn cheap).
Test Slow
