Oil filters - which & where
  • Oil filters - which & where
    I'm looking for a recommendation on oil filters (& suppliers) for a 2.8V6. Its only got 35 000 on it.
    I've got a poxy ryco filter on at the moment - I was in a bit of a jam & needed one quickly. While it fits fine, its actually about half the diameter of the OEM. Obviously an option is to get a genuine one - for a one off I'm okay. But not as a permament solution.
    The ryco filter is only staying on til the next oil change (5000km). Less if I get bored.
    Try Mann oil filter, it is probably the genuine one anyway.
    MM
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      where are you mate, gumby ? without knowing your location its hard to help you.
      As MRL_T5 said, Mann filter is the best.
        I use the Knect filter by Mahle
        Old Skool Passat Power Rules!!!
        1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
          Hengst is the OEM, Mahle or Mann are both perfectly fine alternatives, I use the Mahle myself. It has been reccommended many times that people avoid the Ryco filters.
            On what basis? ... just asking not stirring or anything.
              I was wondering the same thing. So I used the search button
              Apparently somebody did a test on one of the part numbers & the Ryco caused an 8psi pressure drop. Whether this presure drop is universal to all part numbers (I assume VW doesn't have a universal oil filter) I couldn't tell.
              There was also a mention that on Mk1s the oil pressure was causing the internals of the Rycos to disintegrate.
                I used a Ryco on my old Honda and never had a problem - engine had 200000km. Saying that, I would only use a german filter on a german car. No reason other than my own reasoning
                But I would like to see if anyone on here has hard evidence why Ryco filters are no good, at least on VWs.
                NickZ
                Former ride: MY07 Black Polo GTI
                Current: MY09 Blue Passat R36 Wagon
                  I have been in the VW trade for 34 years, I have stated in the past my findings on Ryco on VWs a few times before. Checking oil pressures with different filters ect.
                  Hey, a Mann or Hengst filter is around the same price as a Ryco but if you want to use one of them, go for it. I know, for peace of mind and providing a warrantee on my work, I will always use good filters, (German) and good oil.
                  Its personal preference and peace of mind.
                  Up to you guys as to what you like to use, same with oil.....
                  Cheers, Andrew
                    Ask Tim "dubaddiction" hi has one for VR6 for around $15 "MAHLE" very good price and brand.
                      I've had two friend's with mk1's running "rarelyholdoil"ryco's & blew them to bit's.
                      Why. Cause ryco are only good on holden's & ford's, the other.
                      VW mk1's (I don't know about other model's) run at twice the oil pressure than any other car I know of.
                      That's why most oil pressure guages (if the correct one is fitted as most people fit a 0-500kpa!) are 0-1000 kpa & when cold with rev's can max out the guage.
                      That's 142psi cold! Ryco's just can't take that much pressure.
                        Cheers, Andrew
                        Sweet. Good to see people's personal experiences, so when someone asks me why not to use a Ryco on a german car, I can convince them properly
                        Trust me, I am fussy with what goes in my cars and treating them well. Hell, a VW oil filter sets me back $18 which is not a huge cost difference from the Rycos, especially when the oil costs four times that amount
                        NickZ
                          I managed to find what I was looking for at Euro Auto Wreckers/AVC at Toombul Rd Northgate (Brisbane). Mann filters at $16.50 ea - I bought 2.
                          I lost bugger all oil when I swapped out the Ryco - jacked the car on one side only.
                          It says on the filter its good for 20 000km or 2 years. I'm unlikely to go that long - I usually change the filter every second oil change (about 5 to 7000kms).
                          Thanks for the advice on Ryco. I use Ryco filters on my astra but its got a filter cartridge like some BMWs & Mercs. Not quite the size & weight difference as evident comparing the Mann & Ryco for the passat.
                            Just get an OEM VW filter, it's not like they're so super expensive ($18.00) as to be cost prohibitive.
                            Snowy
                              Hi all.
                              I just replaced my Ryco filter with another Ryco on my Mk1 Cabriolet and am somewhat surprised at the poor performance a number of you have experienced using a Ryco filter.
                              I live in Brisbane and travel daily with my cabby on the M1 at 110km/h+ and in peak hour and have had no problems. The only problem I have/had was some muppet removed the guts from my thermostat and this caused inconsistent coolant temp issues.
                              Really unless you don't change your oil religiously and/or you flog the guts out of your car repeatedly, I can't see a problem with the Ryco filter.
                              Again that's what choice is all about and if I had time I might get a german filter.
                              1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
                              1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
                              1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
                              1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
