Hi, I just had my car serviced at a non-dealer for the first time and while I’m happy with the service (30K) and advice given I happened to see that he used a same funnel for engine oil and brake fluid. He did wipe it with a rag before using it in brake fluid reservoir but I was worried if this would cause any problem. I don’t know why he had to use a funnel for brake fluid reservoir because it’s got a big opening and it was a 1L bottle. It overflowed immediately with the funnel and later sprayed with water to clean the engine bay after service. Is it normal practice to use a same for different fluids?
Anyway the car drives and stops fine but I hear this noise on pressing brake pedal which might be normal as I also hear it in my other car. It’s not a hissing or squishing noise but just the physical noise of the pedal being pressed. I just can’t remember if it was that noticeable though prior to the service.
