I have major paintwork contamination on my CW GTI and I'm not sure how to best go about removing it. Also looking for tips on how to improve my wash regime to reduce the build-up. I wash the car fortnightly, sometimes weekly, but it has always has brown and black specs all over the body - especially the hatch.
Following the advice from this forum, I purchased the Car Care Products Enthusiasts Wash Essentials kit when I first took delivery of the car. I always use a high pressure cleaner (medium pressure, wide spray pattern) to rinse the car before starting to get rid of any bugs or mud spots and to soften the dirt. I then use Duragloss 901 as per recommendations on the bottle, but cleaning is very hard going. There is always a formidable amount of brown spots and black specs. Unless I rub very hard with the cleaning mitt, they can't be removed with regular cleaning. A soft fingernail does remove the spots, but I only did this to ensure the spots weren't permanent stains.
Upon further reading, I went out and bought a clay bar. I followed the tips on the Car Care Products website on how to clay properly, but it takes about 10-15 minutes per 20 cm2 to remove all traces of contamination. The surface turns smooth relatively quickly, but most specs leave behind light brown marks that are very hard to remove - even using a heavy hand with the clay, which I know is not recommended. There is no way I have the time to do this every week or fortnight as it would take several hours to completely clean the car.
Any idea what that stuff is, and if something like a leave-on foaming wash might help. Or if I should just clay until the paintwork is smooth, which takes much less time, and then polish off.
Either way, I'd like my regular fortnightly wash regime to be nothing more than a wash and dry. Maybe add a bi-monthly spray wax in there for good measure.
