Best way to clean exhaust tips
  • Best way to clean exhaust tips
    Hi,
    I have a MKV GT Sport TDI.
    I manage to keep the paint etc clean but the pipe tips are still dirty.
    I'm after any advice on how to clean them.
    thanks
    Murray
    GT Sport TDI
    if they're metal and not painted chrome or anything, just clean then with some soap, water and a cloth or something, and then use some metal polish
      To properly clean and prep exhaust tips you will need
      Steel wool - The finer the better. use 0000 if you can find it
      Acid based wheel cleaner - Hydrochloric (Autlglym Clean Wheels) or Oxalic (Mothers) works fine
      An old cloth
      Metal polish - Autosol Paste
      1. Wash the tips using an old bit of sponge and soap
      2. Split your steel wool into at least 2 bits
      3. spray some wheel cleaner into the tips and let it sit for a min or so
      4. Wearing gloves, use the steel wool to agitate and clean the inside of the tips. If the outside isnt highly polished/chrome then you can also clean the exterior with the acid and steel wool.
      5. rinse out the acid
      6. Polish with the steel wool and some Autosol.
      7. Polish with a cloth and some Autosol to finish it up and get it nice and shiny.
      If you exhaust exterior is highly polished/chrome then just use Autosol on a cloth untill it all comes off. If its very bad then you could spray some wheel cleaner onto a cloth and wipe it round first but dont use steel wool.
      As usual all products are available from www.carcareproducts.com.au (dont forget your discount code!)
      Dan
        i use metal polish similar to autosol...comes up a treat!
          I haven't polished mine but found the mag wheel cleaner works an absolute treat in cutting through the carbon. Didn't even use steel wool and it all came away, although I suppose that depends on how long it's been and how much build up there is.
            so glad my exhaust tips are now tucked under lol
              Rag and elbow grease. Ask ol mate Tim im pretty good
                Yes the best way to clean exhaust tips is to find a gimp, buy him a beer and put him to work
                FOLLOW US ON FACEBOOK
                  thanks everyone,
                  I'll give the mag wheel cleaner a go.
                  Murray
                  GT Sport TDI
                    Originally posted by Mr X View Post
                    thanks everyone,
                    Murray
                    Any luck?, pics?
                    Cheers!
                    .:Polo 6R 77TSI
                    .:Golf MK6 GTI
                    II Kraftwerk
                      Is there anything to keep them shiny and resist the exhaust dirt, mine get coated in soot pretty quickly.
                      When clean they look awesome.
                      *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
                      Economy at 100kph =5.5L
                        Stick it up on blocks for a couple of years
                        Not much you can do, bit like brake dust on wheels, just need to clean regulary.
                        Flipper Dog
                        Now - T-Roc R, Audi Q5
                          Try some of this Nanolex Spray Sealant
                          After the hard work of cleaning them, you can put a sealant on to help reduce dirt build up and they should stay cleaner for a bit longer and be much easier to clean. It will not last as long on Exhausts as other parts (it is good for paint, wheels etc) because of the heat but it will definitely help.
                          Cheers,
                          Mike
                          Car Care Products Australia
                          www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
                          Sydney - Brisbane - Melbourne
                            I use " purple metal polish " extremely quick and glossy as !!!
                              Would Scotchbrite be a good alternative?
                              Present: Mk3 Golf variant.
