how do u avoid scratches and marks when washing a brand new car to protect the paint??
washing a new car's paintjob
 mate, im prob going to miss something here so dan will fill in any blanks , the main aim is trying not to spread dust etc with the stuff u are using to clean the car with
 first use 2 buckets 1 with something like p21s bodyconditioner "only saying this cause thats what i use" 1 filled with clean water
 2. do wheels b4 cleaning rest with seperate cloth and bucket "saves bringing brake dust onto rest of car"
 3. presoak if u can to get rid of most of the serious dirt.
 4. rinse the presoak off
 5. use a good quality or in my case 2 or 3 good mf or lambswhool i keep one for lower sections compared to upper as bottom has more dirt on it.
 6. constantly rinse your mf or lambswool to keep it clean.
 7. use a waffle weave cloth instead of a chamois to reduce amount of rubbing u do when the car is dry.
 or just check out www.detailparadise.com.auOriginally posted by seangtiThe price of the car rarely indicates driver ability/lap time.
 - Don't use a $2 sponge, it will trap dirt & scratch the paint. You need a Microfibre noodle mitt or a lambswool.
- Use some decent carwash detergent. Something like Duragloss or Meguirs Softwash.
- Use one bucket with suds; another with fresh water.
- Hose the car.
- Swish the mitt around in the suds. Wash a panel at a time. Use a back & forth motion - not circular.
- Rinse the panel.
- Rinse the mitt in the fresh water
- Finish car.
- Dry with a microfibre towel. Chamois will trap dirt & scratch the paint.
 That's the short version Last edited by brad; 04-05-2009, 10:17 PM.carandimage The place where Off-Topic is On-Topic Last edited by brad; 04-05-2009, 10:17 PM.carandimage The place where Off-Topic is On-Topic
 and u thought just modding ur car could get expensiveOriginally posted by BL33SU View Posthmmm thanks guys!
 i need to start buying stuff then
 i dont want to count how much ive spent on products lol
 if i was u i would check out a few detailing forums b4 going out and buying stuff save u time and money by getting good stuff first offOriginally posted by seangtiThe price of the car rarely indicates driver ability/lap time.
 Here you go
 I’ve been requested to write a how to guide for people that want to look after their car but with premium based products.
 Before I start ill just say the products and process I use will not work for everyone in the world. You really need to use this as a guide and find what works best for you. In saying that I’m not going to get to technical so you will be able to work out what is what very easily. Some of the products mentioned will be off the shelf variants. All the products I’m mentioning I have had personal experience with. All products are available from Car Care Products.
 Washing
 Washing the car is the most regular thing we do in terms of maintaince. There is a lot of info floating around regarding what to use what not to use etc. There are 3 main principals that if followed will see you washing correctly every time. They are
 1. 2 Buckets
 2. PH Neutral Wash
 3. Microfiber
 Why 2 Buckets?
 When you wash the car the dirt from the car gets transferred to your mitt. When you dunk it back into the wash solution that dirt stays in the solution for next time. Effectively what you’re doing is washing your car with dirty water.
 When you use 2 buckets one is full of wash solution and the other rinse water.
 Once you have hosed down the car (preferably with a HP washer) you get your clean mitt and dip it into the wash solution. Using very light pressure wipe the dirty panel using straight lines, not circular motions.
 Once you have done say a guard or half the bonnet, dip the mitt into the rinse water and run your fingers through the fibres to help get the dirt out. Squeeze the water out of the mitt.
 Return the mitt to the wash solution and do the next panel. As always do this in the shade, don’t let the shampoo dry etc.
 It’s always to go from top down. Personally I do the wheels and tyres last but it’s up to you. I give them a HP rinse before I start and I finish them off by hand. I don’t use wheel cleaners unless they are very very bad and the one I use you can’t buy, however ill still give you some good ones to try.
 Product Recommendations
 Dodo Born to Be Mild
 Duragloss Cherry wash Concentrate
 Aquatouch Microfiber Wash Mitt
 Mint Microfiber Wash Mitt
 Drying
 Once the car is all washed, it’s time to dry. To dry there is no better tool than a Microfiber Waffle Weave Drying Towel (WWDT). I use the extra largo towel, which is able to try a whole Land cruiser or Discovery without being wrung out. You could most likely get away with a large if you wished but IMO the XL is the way to go.
 To dry using a WWDT is very simple. I fold it into quarters to start. I then dry the windows to help prime the towel. This isn’t necessary when new but after a while (like a year) it will help them dry.
 When drying the paint again use no pressure and slowly drag the towel across the paintwork. If there are trace amounts of water left flip the towel and give it another light pass over.
 Once that section of the towel gets saturated turn it inside out and go again.
 Product recommendations
 Mint WWDT
 Waxing or Sealing and Polishing
 Waxing is a crucial step in the care if your vehicle. It protects the surface from the everyday nasties like Bird bombs, tree sap, water deposits etc.
 It’s also very important to note that waxing and polishing are 2 very different things!! I have outlined this in a different thread but I’m about to copy it into here so scroll down if you have read it.
 The biggest misconception I come across in detailing is people that don’t understand the difference between waxing and polishing. I can see how they get confused, it’s the car care product manufactures fault mostly. Anyway here you go.
 Polishing
 Polishing is used to fix paint defects. Polishes can be either chemical or abrasive. Chemical polishers include things like Swissvax cleaner fluid, polylack nano clean, zymol HD Cleanse. They chemically clean the surface to remove contaminants and defects. They will not remove swirl marks. For this you need an abrasive polish.
 Abrasive polish there are many brands. The best I have used is Menzerna. But the Meguiar’s professional range is abrasive as is the optimum polishing range. Abrasive polishes need a machine to reach their full potential. Either a random orbital or a rotary. Abrasive polishes have tiny little abrasives suspended in the liquid. This is what does the work the size and type of abrasive varies depending on the polish you use. The abrasives round the edges of the scratches and swirls so they can no longer be seen. In the case of swirls and fine scratches they are removed. In the case of deep scratches they are always reduced and with the use of wet/dry sand paper can be removed. Menzerna Powergloss has large abrasives which remove large defects but leave the surface full of marring and quite dull. Then there is Menzerna intensive polish this is between the two but on most colours needs to be followed with final finish. This depends on the pad used. Menzerna Final Finish leaves the surface free from defects and with a great depth and shine. Here are some pics so you can see the difference
 After powergloss
 After Intensive polish
 After final finish
 Waxing
 Waxing is the last step you do when washing or detailing your car. That is why you may see it referred to as the LSP (last step product). The purpose of waxing is to create a barrier between your paint and the environment. Most waxes contain UV inhibitors to stop the sun damaging the paint. They also repel water which stops your paint getting etchings from watermarks. There are many may different LSP's out there both natural or synthetic or even a mixture of both. Natural waxes tend to give more of a warmth and a glow. These waxes range in price starting at around $50 and up to $19000. Brands include Swissvax, Zymol, P21S, Dodo and many many more. These are the boutique brand waxes. You can get off the shelf waxes but I don’t rate them for durability or look personally. If they are working for you then go for it! Natural waxes also tend to bead water. This means the water forms tight little beads that run off very easily. If you have a freshly waxed car and drive it in the rain you will find the water will just run off. The lower end waxes and off the shelf waxes last 3-5 weeks before needing to be reapplied whereas the higher end can last 6-8 weeks.
 Synthetic
 Synthetic products do not contain wax. They, for the most part contain polymers or acrylic. These are the two main types of sealers. Sealers include Duragloss 105, Zaino Z2 and Z5, Polylack Nano seal, Optimum opti seal, Klasse AIO, Zaino AIO. Sealants start at around $35 for the boutique brands. I have found Zaino to be the best as it can be layered unlimited times but still remains optically perfect if you use Z2. Z5 will not as it has fillers to hide swirling. Sealants give a different look to wax. It gives a look that is best described as sterile. The paint is shiny but it lacks the warmness and glow of a natural wax. Some sealants like the Klasse make the car look like it has a plastic coating. Some people love this look so leave it others, like myself, don't and then top it with a natural wax. Synthetics tend to sheet water. The water wont form beads, rather it will just run off in a sheet is the best way to describe it. Sealants leave a very slick and slippery surface. Sealants also last a lot longer than a wax with most giving at least 3 months protection and up to 12 months for layered sealants.
 Combination waxes
 These have a mix of both natural and synthetic waxes present. These are waxes like Optimum car wax (OCW). They are a good compromise as they give the look of a natural wax and some of the durability of a sealant. Layered OWC can last 3-4 months.
 Filler waxes
 These are waxes like Meguiar’s NXT range. They contain things called fillers which fill swirls and scratches. The fillers also mute the metallic in the paint so it won’t pop as much. As the product wears off the defects return. I don’t like filler products as they wear off and the surface looks bad again.
 This car has natural wax (Swissol Scuderia ~$200)
 This one has Zaino Z2 Pro layered 3 times and topped with Z8 Last edited by DMS_Dan; 04-05-2009, 11:02 PM. Last edited by DMS_Dan; 04-05-2009, 11:02 PM.
 Polishing
 Menzerna Polish kit
 Heavy Duty - Menzerna Powergloss (High Cut, very low gloss)
 Medium duty – Menzerna P203S (medium to high cut, medium gloss. Follow with PO85RD)
 Light duty/High gloss – Menzerna 106FF (same gloss as 85RD but more cut, use on its own)
 High Gloss/ Very light duty – Menzerna PO85RD (same gloss as 106FF but very little cut, use after P203S)
 Wax
 Dodo Supernatural Paste Wax
 Dodo Colour Charged Soft wax
 (note: the above link if for Orange crush. Look at the other soft wax's to pick the best one for your paint type)
 Dodo Colour Charged Hard Wax
 Dodo Lime Prime
 Dodo Lime Prime Lite
 Sealant
 Duragloss 105
 Duragloss 111
 Zaino Z2
 Spray Hybrids
 Optimum Car Wax
 Duragloss Aquawax.
 Not as long lasting as OCW but it’s applied while the car is wet, is the perfect boost to a car sealed in Duragloss 105. It adds a very nice shine and some extra protection and only takes an extra 3 or 4 mins.
 Ill add more and more to this over the next few days and weeks. If you want something covered let me know. Once its done the car care products guys are going to turn it into a PDF and it will be available for download.
 DanLast edited by DMS_Dan; 04-05-2009, 11:05 PM.
 lol it wasnt easy. its usually one post but it went over the 100000 character limit lol then i had t many pics so its not as pretty as it usually isOriginally posted by jasn78 View Postlol told u dan would fill in the missing parts
 mate as per usual brilliant write up got to say reading ur posts and damians he may be an artist at the detailing biz but find urs alot easier to read.Originally posted by DMS_Dan View Postlol it wasnt easy. its usually one post but it went over the 100000 character limit lol then i had t many pics so its not as pretty as it usually is
 also on ur sealants waxes etc since the op asked should he be careful about applying sealants to new cars?Originally posted by seangtiThe price of the car rarely indicates driver ability/lap time.
 NOOOOOOOriginally posted by BL33SU View Postomg!! i think i'l jst take it to a carwash
 dont mate u just spend a bit of time and money u will do such a better job
 or go c a proper detailer not one of those turkeys on every cornerOriginally posted by seangtiThe price of the car rarely indicates driver ability/lap time.
 Thanks very much mate. It means a lotOriginally posted by jasn78 View Postmate as per usual brilliant write up got to say reading ur posts and damians he may be an artist at the detailing biz but find urs alot easier to read.
 No the first thing that should be done to a new car is to have it sealed or wax'd. The paint has well and truely cured by the time it gets to you so it needs to be protected ASAP
 Then i guarantee that you will have sooooo many marks, swirls and scratches if you do that. Its seriously not hard and if you dont want to do it yourself then there are people out there that will do it for you but expect to pay proper money for a proper job.Originally posted by BL33SU View Postomg!! i think i'l jst take it to a carwash
 wow dan, nice write up ..
 its simple as this
 you like your car
 look after it
 you dont like your car
 take it to a car wash
 and if you dont listen to all the information Dan provided you then you need to also grab some APC and give your head a goos wash!
 Pierre I hate to disagree with you but that test is a bit stupid. It's obviously not a proper handwash if they don't use good tools to clean the car. Using the squeegie thingo was a bad idea and ruins the results of the handwash..
 Oh and Dan that write-up is excellent. There's nothing I have forgotten from the detailing day, but it's still nice and refreshing to go over again Can a mod sticky this thread please? Can a mod sticky this thread please?
 Ray...PLEASE. you've got your car resprayed, get a detailer to JUST give it a wash and seal/wax if nothing else. Dan could do it for you, IIRC it shouldn't be more than 150-200 bucks either! but that could be wrong. DO IT! Mrk Detailing, premium automotive detailing. Paint correction/protection specialist. PM me Mrk Detailing, premium automotive detailing. Paint correction/protection specialist. PM me
