K and N 57S-9501 Intake
  • K and N 57S-9501 Intake
    Has anyone fitted one of these to their 103TDI?
    I'm interested in how well it fitted and if there was any improvement? Also if it was audible and what it sounds like with the lid removed?
    Here's the link to K and N.
    57S-9501 - K&N 57i Series Kits, Performance Intake Kit direct from K&N
    Here it is for a fraction of that price.
    http://www.ebay.com.au/itm/K-N-57S-9501-Performance-Intake-Kit-/131003211069?pt=Motors_Car_Truck_Parts_Accessories &hash=item1e80665d3d
      No, But im liking what im seeing!!!
      I wonder if anyone around does custom tuning to the diesel yeti's rather then 'get a generic tune from overseas', to suit this + maybe a more free flowing exhaust perhaps?
        I just pulled my aircleaner apart to see what's in there and it looks alright to be honest. Which is a shame because I was looking for a reason to 'have' to buy this one. The stock version is a true cold air intake but with that part being a bit convoluted being the only real criticism. I would like a bit of induction noise when I step on it and that K and N would provide that and a much louder version with the top removed as it's been designed to operate as well. Both ways lose the cold air intake though.
        The exhaust looks meaty enough for a 2L. I'm assuming the cat is on top, followed by the DPF, then it's just a straight pipe to the muffler right at the back. Someone said the muffler weighs a ton and it's quiet without it fitted. That would make sense from my experience and it probably causes a few psi backpressure too.
        The join is about halfway so the complete rear section could be removed in minutes, then copied without the muffler and straightening out those 2 right angle bends in the process. A couple of decent tips and it would look good, save some weight, might even have a bit of note and would boost quicker. It could also be returned to stock very easily.
          ^ Need to hear more turbo spool...
            Remember they don't filter to the same standard as genuine and for the life of me I don't know why anyone would do it and the power increase is illusory.
              I had a single cab Ford Courier for about 8 years and put a K and N pod filter on it.
              It sounded marvellous and the filter still looked like new when I cleaned and oiled it. It definitely breathed better at the top end of it's paltry rev range but that might have been the original filter box restricting flow?
              It's for the sound, it's all about the induction roar under load.
              Here's a video clip of a Yeti with a modified air intake. Hope I got the right clip?
              M3 CSL Airbox Induction Sound - YouTube
                I wonder what effect it has on the induction resonance tuning that is engineered in these days.
                  It's used on a N/A engine but I don't think it is when the manifold is pressurised.
                    I can assure you guys there is no more noise with the rear muffler removed. And no you don't get any turbo spool sound either.
                    I have both the K&N panel filter and my rear muffler removed.
                    The DPF kills any chance of noise from the exhaust.
                    Happy Days.
                      Happy Days.
                      Wrapped to find someone who's done some mods.
                      Did you take off the rear muffler complete to the join and then get another pipe made up?
                      If you did can you tell me the cost and the weight of the old part?
                      Did it make any difference, apart from the weight reduction and did the panel filter change make any difference?
                        I can't tell you much about the old muffler. It's in my old mans shed in Bathurst NSW and I'm in Darwin. I was pretty heavy, not something you could pick up one handed (well not easily). It cost me $150 in stainless although the muffler guy is a mate from school (many years ago). It consists of 2 90 degree bends and twin tips. The whole new section is 3" stainless with 2x3" tips.
                        I can take some photos tomorrow, it's dark now and I wont be able to show much under the car with the shed lights.
                        I'm not convinced the K&N filter is that good, considering how good the standard filter is. The K@N is pretty thin (standard K&N) original Skoda filter is very thick with a lot of pleats. More and deeper pleats mean more surface area and more flow.
                        There is no more noise from the exhaust but it doesn't sound like it's busting with heaps of back pressure at the higher revs. Anyone who has reved a later model car with a standard exhaust will know the sound. The sound like a whistle that's being blown too hard to make a whistle sound and it just make the lot of air through a small hole sound. Well the removing the muffle get rid of that sound.
                        Happy Days.
                          I think my next mod will be a heavier rear anti-sway bar just to tune out the understeer a little.
                          Near all new cars are biased to understeer as it's safer for less experienced drivers. If your going to fast, the front understeers, you back off, weight transfers forward, it turns in and away you go. If a vehicle biases toward over steer it takes some more driver input to correct the oversteer but it's generally faster, especially with a all wheel drive car. I did the same to my WRX and it made a hell of a difference.
                          The Yeti is no WRX but it still has the same understeer the WRX had before I fitted the rear anti-sway bar.
                          Most parts are interchangeable with VW Golfs so there is quite a but available.
                          Happy Days.
                            Thanks for the feedback.
                            I would be happy to stick with the 60mm pipe diameter that's there already. The gasses contract as they cool so unless it's 3"[76mm] from the turbo there's nothing to be gained by stepping it up at the back and it's heavier and more expensive.
                            I'm assuming you cut the muffler off and didn't fabricate it from the halfway join?
                            Looking forward to the pics!
                            I was impressed with the stock air filter too, for the same reasons you gave.
                            The muffler on the Mitsubishi Triton 2.5CRD I replaced had been pressure tested at 3-4psi back pressure on the car. No wonder they sound like compressed air.
                            I was impressed with the handling after coming from an 86, even more so when I tried a 1.2 manual with the lighter front end. That was one of the attractions, that I could still enjoy driving as well as being able to buy things and take them home. I bought a new WRX in 1996 and loved it but it understeered something chronic under full power on tight turns, you had to nurse it around and jump on it as you came out of the bend.
                            Please let me know if you find a thicker rear anti roll bar.
                              White line do a anti roll bar and there is a join in the Exhaust just before the muffler so no cutting.
