Electro tailgate no-go
  • Electro tailgate no-go
    Greetings all.
    It isn't showing any faults on the VCDS but the leccy gate, she no-go.
    First motor locks and unlocks fine but the open/close deal is out to lunch. No go on fob, console or door.
    Could something have come away on the relevant motor, some kind of activation arm or something?
    Getting 5 'hazard' beeps on trying to open or close.
    Any ideas greatly appreciated.
    This is on a MK3? Should be covered by warranty at least.
    If it is a MK3, have you had the recall done to remove the signal booster? When mine was done, they accidentally disconnected one of the little motors that releases the luggage cover automatically, could have done something similar in yours that has effected a sensor?
      It's an MY11 Mkii.
      Has been working fine for years.
      May have to pop the trim off to see what i can see.
        did the mk2 superb come with electric tailgate?
          I'm the second owner.
          I believe the previous owner had it all sorted as it was in place but not activated. Was working from fob, console and door.
            Further to this. Will drop into VCDS thread also.
            Friday,20,October,2017,09:50:07:40733
            VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
            VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
            Data version: 20170721 DS276.2
            Ross-Tech: Home
            Mileage: Repair Order: 201017
            Address 6D: Trunk Elect.
            Control Module Part Number: 7N0 959 107 A
            Component and/or Version: HDSG-Modul H11 0802
            Software Coding: 082301C002
            Work Shop Code: WSC 33361
            VCID: B522611A14DEEBEEE9-80E0
            Advanced Identification/FAZIT
            Serial number: 250000031
            Identification: TF7-MNL
            Revision: 41011001
            Date: 07.09.10
            Manufacturer number: 0001
            Test stand number: 0031
            Flash Status
            Programming Attempts(application): 0/0/0
            Programming Attempts(data): 0
            Successful Attempts(data): 0
            Programming Status: 00000000
            Flash Date: 00.00.00
            Flash Tool Code: 00000 000 00000
            Flash Tool Code(data): 00000 000 00000
            Software
            UDS: 01.02.14
            Diag: 01.03.00
            CAN: 01.26.01
            ISO15765: 01.02.15
            UDS Std Diag: 01.01.00
            Theft prot.: 00.00.00
            OSEK-OS: 03.24.00
            OSEK-Com: 04.07.02
            Unknown: 01.00.08
            Misc.
            Hardware number: 7N0 959 107 A
            Workshop System Name: ----
            Equipment/PR Code: 0000000000000000
            Dataset Number: 7N0959107A
            Dataset Version: D009
            ASAM Dataset: EV_HDSGSk462
            ASAM Dataset Revision: 301133
            Car Info
            Chassis Number: -----------------
            VCDS Info:
            Labels: 7N0-959-107.clb
            ROD: EV_HDSGSk462_SK46.rod
            Friday,20,October,2017,09:51:25:40733
            Ross-Tech: Home
            Address 6D: Trunk Elect. Labels: 7N0-959-107.clb
            Control Module Part Number: 7N0 959 107 A HW: 7N0 959 107 A
            Work Shop Code: WSC 33361 790 00999
            ASAM Dataset: EV_HDSGSk462 301133 (SK46)
            1 Fault Found:
            0004 - No Basic Setting
            B2010 00 [137] - -
            MIL ON - Confirmed - Tested Since Memory Clear
            Freeze Frame:
            Fault Status: 00000001
            Fault Priority: 1
            Fault Frequency: 1
            Reset counter: 129
            Mileage: 126440 km
            Date: 2080.14.29
            Time: 10:46:56
            12.64 V
