Close to 20000km now on 2 yr old Elegance TSI. Noting quite a bit of what certainly feels like transmission judder when changing 1/2 and 2/3. Just about guaranteed if car has four adult occupants. Other Superb owners experienced this and if so what sort of response did you get from Skoda Aust. with regard to a full warranty fix? I'm guessing it is "clutches" issue I've seen discussed affecting other VAG products on this and other forums? Car has not been part of either ”7 SPD dsg recalls" of last year or so.
7 SPD dsg issue?
What does "transmission judder" feel like? I got my superb around the same time as notflyingscot (118TSI MY12 with 17,000km on the clock)
I haven't noticed anything that feels too far out of the ordinary, however the gear changes don't feel quite as smooth (when new you could hardly tell when the gears changed)
What should I look out for if it happens to mine?
Pandahill, it's pretty much as the wording suggests. A "juddering" vibration that prompts you to back off a bit on the throttle, the juddering stops and most times the car pulls away fairly smoothly at the next squeeze of the loud pedal. At its worst on a wet uphill start the on/off grabbing of the clutch feeds down to the road as quite violent "axle tramp". It's quite infrequent when only one or two up, much more frequent with four seats occupied. Least that's how it feels on our car.2012 Superb Elegance TSI Sedan- Candy White - Bog Standard!
Dropped it off at Trivett Parramatta this morning. They called within 20 minutes, "your car will require clutch pack" (or words to that effect). Should have it back lunchtime tomorrow. Fingers crossed that a) fixes the problem and b) the new clutches are a lot more durable than the original clutches. Can anyone confirm whether the warranty on the clutch rolls forward for another fixed period from date of replacement?2012 Superb Elegance TSI Sedan- Candy White - Bog Standard!
Car back from Trivett today after completion of TPI2028367/7 (CLUTCHES REPLACEMENT).
Time will tell if issue is resolved. Service adviser claimed that none they have done to date have come back again with similar issue. Fingers crossed he is correct.☺2012 Superb Elegance TSI Sedan- Candy White - Bog Standard!
Make sure you, or whoever drives the car, presses the brake pedal hard when stationary. If you only have light pressure the clutch slips. Test it. Light pressure with slipping clutch equals 1000 rpm and burnt out clutch. Press harder and revs drop to 800 rpm as the clutch fully disengages. Might not be the problem but worth checking as it's a real easy fix.Looking for:- RS4 B7 Avant.
Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
Tks for the tip. Will check that out. Done most of my near 50 years driving in manuals so I'm inclined to knock it into Neutral when stopped. I'm guessing no harm can come of that?
SWMBO drives it at least as much as me. May have to check out her technique. Just wish me luck if I have to correct her methods!2012 Superb Elegance TSI Sedan- Candy White - Bog Standard!
Yeah, my mum used to be able to make a manual sound like it had a torque converter. Absolutely chewed through clutches in her day (finally in an auto now).Looking for:- RS4 B7 Avant.
Originally posted by Paul_R View PostMake sure you, or whoever drives the car, presses the brake pedal hard when stationary. If you only have light pressure the clutch slips. Test it. Light pressure with slipping clutch equals 1000 rpm and burnt out clutch. Press harder and revs drop to 800 rpm as the clutch fully disengages. Might not be the problem but worth checking as it's a real easy fix.
NFS2012 Superb Elegance TSI Sedan- Candy White - Bog Standard!
I drove 4 different DSG cars in 2 weeks. 2 Passat, a Superb and an Octavia. Only the Octy was petrol with the 7 speed and the other 3 were diesel 6 speeders. The Octy and one of the Passats did it. The other 2 6 speeders didn't. Go figure. I was wondering if it was a 7 speed thing only myself at one point. The dealer does claim that that car had an issue - I commented that it was very sluggish off the line - but I don't believe him. It felt like the last 7 speeder I drove.Looking for:- RS4 B7 Avant.
hmmm my new beast has similar glitches... bought the car site unseen in Melb from a dealer... lucky it comes with warranty... off to Lennock Skoda tomorrow for a diagnosis... wish me luck!!2009 Skoda Superb Sedan - 3T ELEGANCE DSG FWD 7 Speed - 148kw 290nM (thank you Northside Eurpopean Mitchell ACT 02+ 6241 1111) 1.8 TSI...114,987km
