Clockspring replacement/coding help
  • Clockspring replacement/coding help
    Hi All
    Recently my clockspring failed on my 2016 Skoda Superb 162tsi.
    I sourced a replacement part 5Q0953569A
    I've replaced the part and am trying to add back the long code (6410) via OBDEleven in module 16 but getting a 31 - Function not available error
    I'm not sure if the software of the new part is the issue or I'm doing something wrong
    Old scan
    16 Steering Column
    System description: Lenks.Modul
    Software number: 3Q0953521BD
    Software version: 0195
    Hardware number: 5Q0953569A
    Hardware version: 075
    Serial number: 20150921501011
    ODX name: EV_SMLSVALEOMQB
    ODX version: 001015
    Long coding: 6410
    Trouble codes:
    No trouble codes found
    New scan
    16 Steering Column
    Serial number: 20160330500114
    ODX version: 001015
    Long coding: 0410
    Trouble codes:
    The new scan shows long coding of 0410 and i can't change to 6410 without the above error. This is the cruise control function via stalk that it is not allowing me to change. Software number is different.
    Can anybody help me here?
    Are the part numbers on the units the same? 3Q0953521, without the letters at the end, does not look to support cruise control.
    Did you get the clockspring by itself or with the stalks?
      Hi.
      I bought the part by itself. I was only going by part number and that was a match. No places actually quite the software but yes that software number coincides with a stalk that doesn't have cruise control. Not sure if there is any way to upgrade the software. Part wasn't cheap either so don't want to buy another in the hope the software is ok
