I hope the stop/start on the Superb is more sophisticated than what I recently experienced on a loan Fabia which was just my third experience of a stop/start equipped vehicle.
Don't get me wrong, the stop and restart worked very efficiently, particularly as it was a manual, but stopping the engine when I had the aircon and fan on high on a 40+ deg day was just ridiculous. First issue was that the fan on high was quite a big drain on the battery and second the aircon cooling matrix soon lost thermal inertia so air in the cabin soon warmed up.
Similar situation at night with headlights on, a big drain on the battery for the duration of the stoppage.
The above and the annoyingly high number of stop/start operations in heavy traffic forced my mechanical sympathy, or in this case 'electrical sympathy' to frequently turn off the function and it was not even my car.
The other thing I am suspicious of is the 'regenerative braking' function, does that mean that recharging the battery after a longish stop does not happen automatically but is deferred to leave room for later braking operation? I attempt to be an economical driver so actually avoid unnecessary use of brakes, so does this mean the battery may be at a lower state than really desirable for longevity?
Regular running down a lead acid battery (even AGM) is always going to shorten its life. Lots of stories across all makes of early failures of expensive batteries with the blame being placed on stop/start operation.
My 2014 1.4tsi manual Octavia does not have stop/start, however sometimes I choose to switch off the ignition when I know that the car will be stationary for a while (and ambient conditions are not too onerous), which means the heavy electrical load items are also turned off. The battery is approaching 5 years old now and still turns the engine over like when new. I also suspect the battery may not be as high spec as fitted in the later stop/start equipped vehicles.
