RS Octavia DSG MY11 Clock Spring Control Unit Slip Ring
  • RS Octavia DSG MY11 Clock Spring Control Unit Slip Ring
    Hi,
    Hope someone can help
    I have the airbag light on and the steering controls dont work.
    I had it scanned and they said it was the clockspring, but quoted me $1500 to fix!!!
    I pulled the wheel off and the part number is 5KO953569B so im trying to find out which variant I can buy
    Ross tech has the list of modules Steering Wheel Control Module Versions - Ross-Tech Wiki
    Part Number 5K0-953-569
    • MFD = Multi Function Display / Board Computer
    • CCS = Cruise Control System
    • ACC = Adaptive Cruise Control
    • MFSW = Multi-Function Steering Wheel
    • AT = Automatic Transmission (Ignition Key Lock)
    Midline Yes Yes - Yes
    Highline Yes No Yes Yes
    Highline TBD TBD TBD TBD
    Midline Yes Yes No TBD
    Highline TBD - TBD TBD
    Highline Yes Yes Yes Yes
    Midline TBD TBD TBD TBD
    TBD Yes No Yes Yes
    TBD TBD TBD TBD TBD
    Highline Yes Yes Yes TBD
    Highline Yes - Yes Yes
    From looking at this I need the highline with 'yes' in all columns. So it would be the 'B' which is the same or 'H' or 'T'
    I found the 'H' here www.skodateile.cz
    'T' here VW CC Passat B7 CC 3C tempomat elektronische modul 5K0953569T 5K0 953 569 T in neue vw oemHighline elektronischen baugruppen( Schlupf Ring) passat b6 b7 cc  Teile-nummer:5k0953569t aus auf AliExpress.com | Alibaba Group
    Can anyone shed some light on which version I can buy that will work?
    And
    Any other suggestions of where to buy it from?
    Clock springs were an issues in a number of cars due to dodgy airbags (separate to the Japanese issue of shrapnel in the face) I know lots of Hyundais had it with their supplier. Haven't heard of if in VAG cars. Might be worth checking it's not a known problem about to be recalled. Certainly I'd be gunning for it to be covered under good will as an airbag woukd be expected to last at least 10yrs.
      yep there is one on is the US VOLKSWAGEN ISSUES VOLUNTARY RECALL : Volkswagen US Media Newsroom
      same part as best as I can tell, not sure why its only US....
        Good luck with VW locally. Where are you based I got my Passat fixed for $400 - $1500 is. Joke
        B6 Passat Wagon No KESSY
          I reckon there is enough of a lawsuit waiting there that they should cover it under goodwill.
            Good luck I have tried with VW before
              I'm in SA, where did you go to get yours fixed OilBurna?
              or can anyone in SA recommend a place to go to ?
                I was in Vic sorry
                  For anyone looking for further information on this
                  Original part number was 5K0 953 569 B . I bought a 5K0-953-569-AL from ebay. It came from a russian seller for about $275 AUD shipped to Adelaide.
                  Also bought a Micro CAN cable from Ross tech to code the new module, which I will be selling soon.
                  All good - steering wheel controls work again and I cleared the airbag fault and now the airbag light is clear too. Happy days.
