I do need an rs4 avant correct! I have heard that the dsg tune would help a lot just haven't convinced the girlfriend its a good use of $1600. I will definitely look into the rear sway bar though. Does that make the ride harsher?
Golf R / R wagon vs GTI vs Skoda Octavia RS - purchase decision
Yes I think everyone who buys an Octy RS actually wants the RS4...
Regards the rear sway bar, it only stops the boat-like side-to-side motion. If you keep the same springs, the ride comfort (up/down) will be identical. You'll just sit flatter through the corners. You can pick up a rear sway bar for ~$300 (both Whiteline and Superpro do them) and the install is direct bolt on, bolt off for the existing one which is tiny in comparison.
Front requires dropping of subframe and requires a few hours to completeOriginally posted by donweather View PostI thought one of the sway bars (front or rear) on the RS was an absolute dog to install?
Rear is 6 bolts and fairly easy - triple square heads IIRC so correct tools required.
Personally, I prefer harder springs as I don't like the way heavier sway bars stop the independant suspension being independant but there's more than 1 way to skin a cat.carandimage The place where Off-Topic is On-Topic
The rear sway bar is a pretty easy DIY. If you lift the rear of the car up on jack stands you can unbolt the rear sway bar straight off and bolt the new one on - job done!
The front sway bar is already reasonably stiff so there's less to be gained and requires the subframe to be dropped to get the sway bar in/out. You really need this up on a hoist and a proper workshop with all the tools for this one. It's not something to be attempted on the driveway...
You'll get 80% gains by upgrading the rear sway bar upgrade - so if you're looking for the best bang for buck just do the rear.
Too right!Originally posted by tigger73 View PostYes I think everyone who buys an Octy RS actually wants the RS4... .
I'm working my way up there which is why I went from the Octy to an R36...next stop RS4! (In my dreams)
Sent from my HTC One M8 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Damn Straight. I would consider the Golf r wagon if it came in a manual.....R36 doesnt so that is out.....Originally posted by kamold View PostToo right!
Then again getting a manual RS4 could be a challenge.....but then I cant afford one, so will keep dreaming of that manual RS4 wagon....2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
Also consider the Golf Alltrack, it's down on performance but still has the AWD and slightly higher position.
Pity the R Wagon has that ugly
Carbon leather!2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
You could chip (flash) the Golf Alltrack ecu. The Superchip version gives an extra 42kw and 93Nm.Originally posted by shauno View PostAlso consider the Golf Alltrack, it's down on performance but still has the AWD and slightly higher position.
Carbon leather!2008 Skoda Octavia Elegance TDI 4x4 wagon
Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
That'd be pretty decent, comparable to a stock vRS!
I really like the Mk3 Octy, I think if it was AWD it'd be an easy choice... Pity they're $45k+ fully loaded, more than a GTI2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
Price up a GTI with all the fruit - Octy usually works out cheapeer.Originally posted by shauno View PostThat'd be pretty decent, comparable to a stock vRS!
I really like the Mk3 Octy, I think if it was AWD it'd be an easy choice... Pity they're $45k+ fully loaded, more than a GTIcarandimage The place where Off-Topic is On-Topic
