Paddle shift retrofit to new Scout?
  • Paddle shift retrofit to new Scout?
    Anyone know for sure if the we can retrofit to RS steering wheel to the Scout 132tsi/135tdi to get paddle shift?
    C
    if it were possible at all, i would imagine it would require the following at a minimum:-
    1. new steering wheel with paddle shifters
    2. new steering wheel controller
    3. vcds coding changes
      Paddle shifts are a gimmick. You ll use them for a couple of days then get bored with them.
      2014 MY14 Corrida Red Elegance Wagon TDI
      2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
      2011 MY12 Yeti 77 TSI DSG.
        Not a gimmick, I use them all the time on my R. When I'm away and renting normal golf I miss them. Use of them would also incourage my wife to correctly place har hands on the steering wheel!
        So no one done it?
        C
          not a gimmick for me either.
          i use it often, though not ALL the time.
          also encourages me to place my hands at the correct position on the steering wheel.
            So no one done it?
            C
            Do you really think your missus would be bothered?
            We've had about 3 cars with paddle shifters (inc the current one). Wife never bothers. Thumb in bum, mind in neutral. They just like to wear the brakes out as quickly as possible and attempt to put peoples head through the windscreen.
            It's been done on other VAG cars inc Octavias, Jettas & Tiguans. So maybe search for those for some hints & potential issues.
            Post #2 has the answers.
            It's a suck it & see situation. You probably need a wiring loom from the steering wheel to the controller. Sometimes you need to change the controllers, other times you just need to enable the flappy paddle channel in the controller.
              Thanks, i'd like to know before putting money down to buy the car, otherwise we'd probably step up to alltrack or second hand A4 avante/allroad.
              If no one has done it, thats simple.
              C
                I just installed a paddle shift wheel in my Tiguan Kamold coded it for me good for over taking and slowing down using the gears
                  Definitely not a gimmick! I used to use them a lot - even when hiring Skodas in Europe, my fingers would instinctively reach for them even when they weren't there. I'm also getting a Scout and this is the only thing that I'm sad about.
                  MY15 Octavia Scout TDI135 Moon White Tech Pack Panoramic Sunroof Polar wheels
                    What you need to do is get someone with the model Scout you're looking to buy to run a VCDS autoscan to work out what steering wheel control module it's running. Likely if it already is running a multi-function steering wheel it will have the controller that supports the paddle shifters.
                    Next you have to source a steering wheel with paddle shifters and possibly an airbag if the shape of the airbag/connectors is different. A good place for steering wheels is here: Skoda Octavia 3 - 5E - Multifunction Steering Wheel - With DSG Paddle Shift - 5E0419091AF
                    It's not a difficult job to retrofit but working with airbags is a hazard - suggest getting a professional to do it. Job shouldn't take more than 30 minutes with the right tools.
                    - Tigger73's 125TSI Build
                      C
                      All you have to do is search the forum for several examples.
                        Now we're talking, thanks.
                        C
                          C
                          No problems. As brad says just run a search for paddle shifter retrofit and you'll pull up a number of threads on the topic. There's even a few youtube videos if you're keen to DIY. I have personally installed a Golf R wheel into a Tiguan and it was relatively straight forward once the airbag was removed - which is a bit tricky the first time you do it.
                          If you can find a steering wheel with paddles that will fit your airbag you can save yourself some $. Something like this: OEM 5E0419091AF CWE Multifunction Steering Wheel for Skoda Octavia 3 with DSG Shift Paddles for 235.00 € - Škoda
                          I used to use the paddles all the time until I had the DSG software tuned. After that I hardly used them at all as the car shifted how I wanted.
