Excuse me if this has been discussed before - I can't find the information I'm looking for using the search. And I'm new! (ish)
My, newly acquired RS wagon has just begun to not start, due to the battery not turning the engine over. I noticed it was labouring a couple of days ago, and now it mostly fails to turn for more than 1 second.
I've been straight to a local battery specialist who advised me that the battery is fine, and that the alternator is charging it.
Josh, at Camden GTI, on hearing the engine running said that he thinks it is the Dual Mass Flywheel beginning to fail that is causing the problem.. There is an audible tapping noise, which is most apparent (to me) when starting and stopping the engine.
His explanation was that the failing flywheel is causing a large load for the starter to turn over which drains the battery. While I understand the load/drain suggestion, would the battery not be charged enough after a drive, of say 30 mins, to restart the engine?
If this is the problem, I want to fix it in the cheapest way, which appears to be by replacing the DMF with a SMF. Either way, it looks like it is going to cost..
I have been researching online to source a decent priced SMF clutch kit for my RS (I'd be asking CGTI to fit at C. $650 labour):
2007 2.0 RS BWA 1Z engine. 6-speed. TFSI. 147kw
I haven't had much luck in finding a supplier, other than on eBay:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=261104807838&globalID=EB AY-
which totals $700 AUD delivered from UK.
Most parts search databases on clutch supplier websites provide the DMF as their only solution for replacement, in my experience so far.
Does anyone one have any experience and / or suggestions with this problem causing the battery drain issue which I am experiencing?
Any good suggestions on a cost effective (cheaper) way to source the SMF clutch kit - if required?
Thanks,
Chris
Thanks,
Chris
