Spare tyre
Originally posted by Diesel_vert View PostThe primary reason for its use on aircraft is safety, as nitrogen does not support combustion.
Nitrogen, like other gases, follows the ideal gas laws - that is, pressure is directly proportional to temperature for a fixed mass and volume (for instance, the inside a tyre, which is close enough).
Yes O2 is combustible or provides the combustion of other materials, so you remove that from the equation in a plane.
In F1, they are concerned about that 2% that is left over. Hence the desire for a pure gas in the tyres for a level baseline and to remove outside factors well looking for 100ths of a second.
If they are filling the tyres for you with Nitrogen, do they extract all the air in the tyres first to crate a vaccuum then fill with Nitrogen? If not then you still have a component that is not pure Nitrogen anyway. Just a larger percentage of Nitrogen per volume.
If you really want better performance from your tyres, forget nitrogen, instead regularly check the pressures with a non-service station pressure gauge. Always use the same gauge for consistency and alter accordingly. Bearing in mind outside air temp, driving distance and speed will all affect the pressure.2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
