Originally posted by dArK5HaD0w
View Post
19 x 9 Rear Will it Fit?
W is the speed rating - XL means eXtra Load2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Some tyre loadings - not looing very good for wide 19":
255/30/19 91Y
245/30/19 89Y
235/30/19 88Y / 87W
225/35/19 88Y
225/40/19 89Y / 93Y
The Golf guys are using 235/35/19 (it fits in the front wheel arch)
Options for that tyre are:
Continental ContiSportContact 3 - 91Y
Continental ContiSportContact 5P - 91Y XL
Continental ExtremeContact DW - 91Y XL
Dunlop Sport Maxx RT - 91Y XL
Goodyear Eagle F1 Asymmetric 2 - 91Y XL
Michelin Pilot Super Sport - 91Y XL
Pirelli P Zero - 91Y XL
Pirelli P Zero Rosso - 91Y XL
Yokohama S.drive - 91Y XL
Bridgestone Potenza S-04 Pole Position - 91Y XL
Bridgestone Potenza RE-11 - 91W XLLast edited by Martin; 11-09-2014, 10:47 PM.2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Those sizes are bmw 335i sizes. I thought its 2 " will be the max you can upsize without being defect. 225/35/19 should be fitted wuth 255/30/19Originally posted by Martin View PostScrubbing is a steering term - I presume you mean rubbing
It will depend on your offset, tyre size and ride height
In NSW you are not allowed to increase rim width by more than 1"
You may impact your insurance cover or even get defected (unlikely?)
Next problem is the tyre size, to keep the same rolling diameter you need 255/30/19
That's an odd size, may be hard to source, will cost a fair bit more than the stock tyres,
they will spray dirt down the size of the car, they almost certainly will rub
225/30/19 will give a 0.7% diameter change - will be stretched on a 9" rim (but is a legal tyre/rim match)
235/35/19 will give a 1.5% diameter change
Total tracking may be 2" wider - hence 1" wider wheels each sideOriginally posted by kaitan View PostI thought its 2 " will be the max you can upsize without being defect.2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
