What Ceramic pads would u recommended? - 2011 vRS
  • What Ceramic pads would u recommended? - 2011 vRS
    i'm planning to have them changed at the 75,000km service coming up in a few weeks. it still has the factory pads.
    I want to reduce the brake dust being generated, hence looking at ceramic pads.
    i'm leaning towards Hawk HPS.
    is the EBC stuff any good?
    I've head good reviews about stoptech ceramic pads, but I don't know if they r available here in oz.
    any other recommendations?
    and finally, i'm assuming the pads for a mk6 golf gti will fit no probs.
    What discs do you have? the original euro discs, or aftermarket ones? Slotted DBA's will help make a large difference to stopping, along with pads.
    Have heard that QFM A1RM pads are bloody awesome, and well priced too. Brakes Direct - Queensland Friction Materials
      still factory discs.
      factory pads.
      still life left in them.
      a BBK would b tempting, but I can't do that now.
        Wow your factory discs have lasted this long? Generally euro discs are made of butter due to cold climate performance required. I thought it was a given that ~60K will be disc replacement time.
        Look for some slotted discs, and get those QFM pads......BBK will go to the back of your mind! If you're looking at doing it on the cheap, then just a set of pads might be ok. Not sure how much life you will have left in those discs though!
          I'm using A1RM also. they warm up quickly and bite well, even when cold.
          IMO the factory brake size is pretty damn good. upgraded pads and rotors will only assist that.
            Have heard good things about ATE ceramic pads, might try them when mine are due on the Octy and Golf.
              yeah, I too am surprised that they've lasted this long.
              the discs on my last euro car had to be changed at 45,000km!! appalling.
              I reckon the DSG has something to do with the brake pads n discs lasting this long. the dsg in drive or sport mode engine brakes very efficiently, reducing the amount of brake pedal I need to apply
              so far the QFM seems to b popular. r they ceramic?
                Slotted pads will make no difference to braking unless you're cooking your brake pads on the track. Save your money and get better fluids if you're doing track work.
                Brakes direct tend to recommend Remsa pads for street driven cars. QFM A1RM are more for track work.
                I've used QFM HPXs and remsa pads and have been very happy with the results.
                I'm on 100k with my Mk5 GTI. On original front pads and discs and changed my rears at 90k ( with Remsa's) 95% city driving but I read the traffic.
                Hoping to get 120k out of the fronts, will depend what they look like at the 105k service. If they won't last 15k I'll get it changed.
                The dealer recommended a full brake change @ 75k lol.
                MY07 Red GTI 3 Door
                  A1RM is ceramic. yes they are a track pad, but they are 0-850degrees and great for both scenarios.
                  HPX are perfect for street, 0-450degrees (I think) also a great pad.
                  +1 on better fluid. id recommend something with a dry boiling point of over 300degrees for track work. street only? normal DOT4 is fine.
                  talking about euro brakes, my wifes 500 needed all 4 corners done at 43k. pads and rotors. wasn't cheap, but thankfully brembo make factory sizes for her model.
                    You can have two types of fade. Fluid fade and pad fade. Slots help vent the gas that builds up between the pad and the disc. Better fluid stops you boiling it from heat. Better to do both (since a change of discs is surely imminent). Really good fluid is also really hygroscopic (absorbs water easily) and goes "off" quickly. I used to use motul RBF660 on my bike when I was tracking it a lot, and it was rooted within 6 months (needed a flush every 6 months). I ended up getting speed bleeders (one way valves on the bleed nipple) so I could do it in 5 mins. Castrol (SRF) make the best brake fluid, but its insanely expensive - $90-100 for 500ml......and needs to be re-bled frequently.
                    For a street car, i'd recommend better than std, but not crazy expensive race stuff.
                      I don't do any track days.
                      I might do a couple of spirited drives here in there, but 95% of the time its normal street riving......and 90% of that is driven by my wifey!!
                      i'm quite happy with the current stopping power/performance.
                      the front rotors/discs appear to have only have a 1-2mm lip.
                      the rear rotors/discs don't have any lip at all.
                      i'll get them checked (for wear) professionally at some point.
                      so, presuming my rotors/discs still have some years left in them, i'm just focusing on replacing the pads with ones which generates less brake dust.
                      I won't b surprised if the pads currently on still have some life left in them.
                      but i'm sick of cleaning the front wheels - so out with the oem pads
                        +1 for the QFM HPX PADS. had them on my last three cars plus the wifes.way less dust and excellent performance for street duties. i tried the remsa but were way more dusty than the HPX. dont know if they are available for your car but i would definately get them if you can. GSL Rallysport stock them.dont let them talk you into the Remsa.they will tell you the dust factor is the same as the HPX,but trust me it is not.i found out the hard way and had to listen to my wife complain for months till i changed them.
                        cheers
                        warrick
                        sigpic2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
                          While I don't disagree with you, slotted pads and better than Standard dot 4 will be wasted by 95% of drivers, including the OP.
                          To the OP, remsa pads are perfect for your needs, equal to OEM performance with much less dust.
                          The issues is you should machine your disc if you are changing pads types/brands. If you machine it may be undersized. Plus due to the cost of machining, you may as well replace it.
                          I paid ~$100 for the remsa's and $110 for RDA discs for the front axle (rear pads cheaper and discs more expensive).
                          MY07 Red GTI 3 Door
                            Agreed, but the small cost difference between slotted and std, and the small cost difference between std and better fluid, along with better pads will make a difference those times (the 5%) he is driving spirited. Just aim for pads that have the same cold performance, but better hot performance. Most aftermarket will have that
                              ^^^ This
