Octavia II vRS 4 Motion conversion
  • #31
    I've had the rear inside guards foam/metal bracket cut, else it would have shredded tyres, daily, let alone towing.
    I've had VW-Racing springs (Martins old ones) for around 100,000km now, so not adjustable.
    The front doesn't poke much, if at all... but on hard cornering (hill climb - Macquarie Pass ) the fronts will scrub on the top of the wheel arch. No paint damage yet, so fingers crossed!
    Not including hers...
    • #32
      So with stock suspension will the 18*8 ET45 with 235/40 tyres and towing have issues do you think?
      How much do the VW Racing Springs lower it from stock?
      • #33
        Some risk of the 235's rubbing the guards during larger suspension travel
        (Lex had this problem but I don't know what wheel offset he was using)
        No problem with 225's
        Not a good option, car can bottom out and have dangerous reactions
        If you want to go lower, do springs and shocks together, $$$
        • #34
          Thanks Martin. I'm not intending to lower the car. Was just interested how much the lowering caused mysticality's rubbing issues over stock.
          • #35
            If you're going wider wheels, get the inside metal bracket on the rear guards cut off. Else it *will* shred your tyres.
            Stock 18x7.5 ET51 is not a problem, but x8 ET45 most definitely is. Won't be a problem at stock height on a flat road, but once you get some suspension flex into the mix it'll end in tears.
            • #36
              Hmmm. Sounds like 225s are the way to go then. Thanks.
              • #37
                Yes, stick to 225 - they are already decent sized feet and we know they work well
                You won't see any improved street handling from 235 and are likely to get a bit more noise, plus rubbing issues
                Unless the 235 tyre was cheaper I just wound't bother
                • #38
                  Back to the original topic, I have been looking into this
                  The Mk1 Octavia was a lot different
                  The Mk2 Octavia is a shared platform and the transplant is possible
                  I've talked to a few wreckers, I just can't make the numbers work, better to buy a 4WD/AWD
                  (Not interested in shipping the gear from Germany)
                  For now I'll have to entertain myself replacing LED's in the instrument cluster
                  • #39
                    What sort of outlay would the parts come too from a local wrecker? I am still pretty keen on this going ahead in the near future.
                    I guess finding a frontal damaged Scout that is a write-off would be the preferred route, complete donor to pillage parts from where does one look to purchase written-off cars from apart from classifieds?
                    Google here I come...!!!
                    • #40
                      There is a scout for auction at pickles - written off, believe it's based in Queensland. If you pick it up, pm me! Would like a part or two, not required for your build, off it
                      EDIT: Auction is on 21 August 2014 - Online
                      07/09, Skoda, Octavia, Wagon - Pickles Auctions Australia
                      • #41
                        That Scout is a MK1 - the rear suspension may be very different to our MKII's
                        I would love to get one onto a hoist and check it out
                        You're going to be spending ~7k on parts easy (more if you want the R32 brakes)
                        Then there is a the labor
                        Then you need to get the Haldex controller working with the car
                        (if you're really serious, you would then go to stage 3!!!)
                        • #42
                          Just get the golf wagon r line which is supposed to be coming out next year.
                          • #43
                            Don't you mean the Golf Alltrack?
                            The R-line is only the body kit + lowered suspension but the Alltrack will be an AWD version with raised suspension. I guess you could tune and lower an alltrack and end up with an AWD sportswagon.
                            Will still have to see what engines this one comes with.
                            - Tigger73's 125TSI Build
                            • #44
                              No an actual Golf R Wagon
                              • #45
                                Hmmm I thought the scout would be the same chassis/platform as the Mk2 Octavia that could complicate things, It would be going past stage 3 to a BIG turbo and forged/built engine I really want to go pretty nuts on it maybe even an engine swap to a VR6 but I don't want to load the front with too much weight Would an R32 donor car be the best solution do you think?
                                It will be a long build process though with more kids and a house on the cards, hopefully with a nice garage/shed for building cars in
                                I recently watched the Mighty car mods 11 sec gramps build and it has really motivated me to build my own car as much as I can, I would save on labour and learn some awesome new skills along the way.
                                I'm really excited about the prospect of an AWD Octy RS with a savagely built engine, can't wait to finally start the work...!!!
