Why not go the other way and consider stretching a 215/40 tyre on your 7.5" rim? Very small stretch. 215/40s are pretty reasonably priced. You can get kumho ku31s in that size for less than $200/corner. The ku31s are a fantastic grip tyre but they are a bit noisy and you'd be lucky to get more than 25,000kms out of a set.
Originally posted by MightyCarMods
I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
A 215/40 R18 89Y XL tyre will fit on a 7.5 J wheel quite comfortably (approved wheel widths are 7.0 J to 8.5 J).
However, fitting such a tyre on an Octavia will render the vehicle unroadworthy because of the load index (unless the vehicle manufacturer has approved that particular fitment).
Ahh yes, I forgot that most 215/40r18s have a 89Y load rating.
In reality, how heavy is the Octavia?
I know manufacturers can be a bit OTT with load ratings.
Any chance to slap on a different tyre placard?
On a FWD vehicle, you'd at least have to consider its front GAWR (gross axle weight rating, i.e. the maximum permissible axle load) and the combined maximum load capacity of the tyres fitted on said axle.
A load index of 89 equates to a maximum load capacity of 580 kg per tyre, which is 1160 kg per axle.
If there is a risk of overloading the tyres, you may also have to increase the original tyre inflation pressures (which are only meant for the original tyres) to compensate for the reduction in load capacity of the new tyres, as load capacity (up to its maximum) is proportional to inflation pressure.
