Octavia Oil Filter and Cabin Filter $
  • Octavia Oil Filter and Cabin Filter $
    I'm changing my oil every 10k
    It's cheap insurance and I'm trying to compensate for the extra kw
    The aircon is not smelling great these days so I need a new cabin filter
    Stopped into my local Skoda parts dealer on the way to work to get an oil filter and cabin filter
    Total cost was $60 - add the oil (Liqui Moly) $65 - pretty cheap piece of mind
    Not bad.
    I got my cabin filter from ebay for $20 delivered.
      Where the heck are you getting LiquiMoly oil for $65? I assume you are getting 5L of 4200TopTec? Im paying $85-90 for that stuff.
      Also i see Bold Sport have recently added OEM VW oil filters for the 2.0TSI engines for $15: Bold-Sport.com :: OEM Oil Filter - Priced Each
      B9 Audi SQ5
        I can't even buy it at trade price for that, even if I buy it in bulk.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          Factor in shipping & they're about the same as here, tho...
          Coming on Sunday, Lucas? (want to look under your bonnet & drool...)
            Last time I bought the oil & cabin filter it came to ~$40
            Martin
            Don't forget there's the guy over near where you work that does US import Mobil1. It's very good value
            GL Lubricants
              Thanks heaps Brad - great tip
                Sorry to dig up an old thread - better than starting a new one. I looked in the manual but can't find what I am after.
                Pollen vs in car cabin filter .. are these terms used interchangeably ? I have seen some videos and can't work out whether it is the same thing or two different filters ?
                Looks like my Mk2 Octavia RS will have the "in car cabin filter" that's in the passenger footwell somewhat similar to this video:
                Is there another filter under the bonnet / windshield protection or is that for a different model Octavia ?
                This looks like the right filter for me - which I will probably get the OEM from the dealer: Wesfil Cabin AIR Pollen Filter WACF0025 | eBay
                EDIT:
                Mk1 - under windshield
                Mk2 - passenger footwell
                RS
                R
                  There's only 1 unit in the footwell
                  Cheapest I can find but I've bought for <$20 delivered
                  Cabin AIR Filter FIT FEB 2009 Skoda Octavia 1Z 2 0FSI Petrol 4 2 0L BVY | eBay
                  /searches
                  $20
                  Activated Carbon AIR Filter Fits Volkswagen 1K0819644B 1K0819644 1K0819653A | eBay
                    Cheers brad !
                    RS
                    R
                      The filter was clean as. A few small leaves were in the filter only and not wet/mouldy or smelly at all.
                      I just vacuumed it and maybe that should be satisfactory - I had the issue of smelly air when changing between a/c on and a/c off.
                      RS
                      R
                        the smelly stuff is microscopic.
                        Change it every 12m regardless of how it looked
                          You can get an aerosol can of goo you squirt in the AC to clean out mould that supposedly grows in there.
                          2008 Skoda Octavia Elegance TDI 4x4 wagon
                          Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
                            Use this https://www.carcareproducts.com.au/p..._klima_cleaner
                            or this
                            https://www.carcareproducts.com.au/p..._con_sanitizer
                            I've run the autoglym on my sisters jetta with good results. Prime the cap, place in footwell and run the aircon on high and recirculate without a cabin filter. Once the can is depleted, pop in the new filter and run for a few minutes.
                              Cheers guys ... In due for some products from the boys at carcareproducts and will try the autoglymm out
                              RS
                              R
