Originally posted by K1W1
View Post
Night Time Assist - Steering turns on Fog Lights
light from a lower point gives a better indication of how close you are to the car in front when you see the reflection.Originally posted by donweather View PostWhat would be the point of this? Aren't you looking the other way when in reverse?
As darkshadow mentioned, I also look forward when going backwards
ooh! I wonder how that is coded?Originally posted by dArK5HaD0w View Post+1. mine too.
and in reverse, both foglights r activated.
Would be good if in reverse both the rear fogs came on as well as the reverse lights.
PS: I had turning lights on my U13 Bluebird.carandimage The place where Off-Topic is On-Topic
Yes, Dad had a U12. The U13 was streets ahead in all respects.Originally posted by zei20t View Postthe U12 pintara was before that, and it had turning lights too
replace your reverse lights with LED ones and youll have some extra brightnesscarandimage The place where Off-Topic is On-Topic
Originally posted by dArK5HaD0w View Posthey hey.......unfortunately i haven't been able to find any specific vcds for the non-vrs octavias.
this is the coding i used:-
Control Module > [09] Central elec / Coding / Long coding helper / byte14 / bit 5, Check the box.
Exit
Do it
maybe the above will also work for the 118tsi
got my VCDS cable today and did this exactly as you stated above... I can now say that this works 100% with a 118tsi
Funny how I can do it but Skoda said it can't be done.
"Funny how I can do it but VW said it can't be done."Originally posted by hitman View PostFunny how I can do it but Skoda said it can't be done.
good to hear the same VCDS coding worked for u
woOotLast edited by dArK5HaD0w; 16-04-2013, 08:53 PM.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
