SupaSkoda LED Boot lights
You I did this too. Didn't do the 7 winds thing tho, but took about an hour to get it back together, and pulled the entire glove box out.Originally posted by donweather View PostWorked it out from this pic and the words in the above thread. The key secret is the 7 winds of the spring!!!
Octavia 11 glovebox query - not a wind up! What should it contain? - Skoda Octavia II (2004 - 2013) - BRISKODA.net - The Skoda Forum and Community
The secret to swapping the glove box is to pull it out from the inside, but pop the cover off from the edge closest to the back of the glove box. If you look at the plastic diffuser cover, you can see where the indentation to prize off is, how the %&*# you get a screw driver in there is beyond me, even a little stubby flat will be difficult, or really strong finger nails might do it. Lucky a LED should last 15000 hours.
I pulled the light out to see what bulb was required. Have since done full led change over, EXCEPT glove box.
What Octavia do you have? My front reading lights are the same as the back. 2 x vertical on the sides, and a horizontal in the middle.Originally posted by donweather View PostAll other lights are a 10 sec change over. Bit dissappointed with the reading lights in the front. They're horizontal but the LEDs provided from LEDPERF are vertical, hence all of their light shines forward at the light housing rather than down into the cabin, if that makes sense.2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
Wow, you pulled the whole glove box out to replace the light!!! That's impressive. I have a Mk 2 RS Occy. My front reading lights are installed horizontally whilst my back reading lights are installed vertically, if that makes sense.
So my rear light assembly looks like the pics on this page
Interior Light bulb upgrade - Skoda Octavia I - BRISKODA.net - The Skoda Forum and Community
But my fronts have the LEDs pointing forward/horizontally with the outer shroud behind the globe being curved to try and reflect some of the light downwards. It wasn't an issue with the old globes as they lit up 360 deg, but the LEDs supplied from LEDPERF point forward, instead of down.
removing the glovebox is a 2 min job.Originally posted by donweather View PostWow, you pulled the whole glove box out to replace the light!!! That's impressive.
I did it many times - 1st time while retrofitting the Bluetooth module; 2nd time when installing the footwell lights.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Pulled the glove box out to get the bulb housing back together and back in when it was in bits......Originally posted by donweather View PostWow, you pulled the whole glove box out to replace the light!!! That's impressive. I have a Mk 2 RS Occy. My front reading lights are installed horizontally whilst my back reading lights are installed vertically, if that makes sense.
My front lights housing is the same as the rear, so you need leds like in the pic here. Bulbs like the bottom left of the picture.
SKODA OCTAVIA II FL INTERIOR LED SMD Bulbs KIT WHITE CAN BUS | eBay
This is where I got my kit from for the RS.
Have a good look in the front light housing as see if there is another slot for the bulbs behind the shroud?
Some A4's had the front light housing set for different bulb configurations, you may have something similar?2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
what's ur thoughts on this kit?Originally posted by spud75 View PostSKODA OCTAVIA II FL INTERIOR LED SMD Bulbs KIT WHITE CAN BUS | eBay
simply replace & enjoy?
good practical light?MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Honest opinion.Originally posted by dArK5HaD0w View Postwhat's ur thoughts on this kit?
Yes replace and enjoy.
Not as bright as the A3 kit I got. A3 has slight blue tinge but ridiculously bright. You can see everything inside the car from 20m away.
Boot not as bright as the pics on superskoda, but better than stock.
Check you puddle light fittings and message them to ensure they send the right ones.
The interior dome lights are white, not bluish tinge and much brighter than stock. All bulbs are plug and play. No errors, or stuffing with resistors as I had to in the A3. (exact same bulb holder and bulb as RS)
Yes good practical light, white, not too bright.
Why I buy again? Yes.2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
thanks for that.Originally posted by spud75 View PostHonest opinion.
I don't have puddle lights, but I do have footwell lights, front & rear - so i'll have to change these too.
the footwell lights do use the same bulb and housing as the boot lights, so it shouldn't b an issue.Last edited by dArK5HaD0w; 10-07-2014, 09:03 PM.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
