I'm pretty sure you can disable the cold bulb warning via VCDS.  Just a thought.
RS HID/LED fog lights
 ThanksOriginally posted by zei20t View Postnup cant.
 golf mk6, Octavia 1z(FL) and equivalents with similar CECMs cant disable this function.
 golf mk5, and octaiva 1z(pre-FL) can disabled it per channel.
 Didn't realise they had removed the functionality from later vehicles.carandimage The place where Off-Topic is On-Topic
 Hey guys,
 Perhaps you'd be able to help me. I believe this to be the same sought of set up except that im looking to hook up a vrs drl light bar which I believe shares the same 3 pin connector. I've ordered the connect but am having issues with hooking up the pins in the connector and crimping. Off my last set of pins, when I plugged in the connector I don't think it was connection properly as it was pushing the wires out of the connector.
 Would anyone be able to help?
 My plan was to either 1) power from existing 2 wire DRL connection or 2) use a purchased drl relay and hook it up to the battery.
 @zei20t, any chance I could grab some of those pins off you? Happy to pay.
 Cheers guy looking to get these unconnected DRLs finally shining haha.
 that's the one, or finally I was going to order the harness off here www.skodateile.cz facelift but it turns out its outta stock. That's actually how I found out the part number to order off deytrade, great thanks for the help
 Very old thread, I know...
 But how would I wire these DRLs as they were intended?
 Ie, Full brightness with headlights/parkers OFF, Dimmed with headlights/parkers ON?
 Code fogs to be used as DRLs;
 Get plugs to fit drl, get plugs to fit car side (make my own adapter/extension so I don't have to cut anything on the car)
 Negative fog light wire on car side goes to negative pin on drl;
 Positive fog light wire on car side goes to full brightness positive pin on drl;
 Where do I wire from to trigger the dimmed pin on the drl when headlights/parkers ON?
 Thanks to anyone who can help.
 just extend a wire from your current parking light/DRL to the 30% pin on the LED fog lights.
 the rest should be ok to use as a normal fog, assuming you get the correct plug.
 youll need to do some VCDS coding to make the fog light be the DRL - it also may not be possible
