Hi,
Recently had my RS serviced (30k) and had wheels and tyres rotated, balanced and aligned. Car came back with faint rumble in front end that I didn't think much of initially but it steadily got worse, sounding something like the rumble strips on the side of freeways! I went back to the dealer and they advised that the tyes that had been on the back had saw tooth wear (lots of threads about this, I know). They advised that as they were now on the front, the noise was much more obvious.
I then got a second opinion at a tyre and they demonstrated the affect of saw tooth wear... Run your hand one way around the circumference of the tyre and it feels smooth, run it the other way and you feel the pronounced edges of each tread block. I was convinced, so bought 4 new Goodyear Asym 2 tyres. These are premium tyres in my book so was expecting good things. To my dismay the noise was still there, maybe even worse. It drowns out all engine noise at any speed above 40kph!
I then did some reading on this forum and Briskoda re wheel alignment. Took the car to Pedders and they did another alignment and I insisted on seeing the before and after numbers, I also asked them to dial out some of the camber on the rear wheels. Numbers show that the toe in was off by degrees and camber on the front was not in spec either. Rear camber is now under 1 degree (was closer to 2 degrees prior).
Result is the car is tracking nice and seems to roll better too... (rolling up to lights seems to go on forever where previously it felt like the brakes were on ever so slightly) But the Bl00dy noise is till there!!! I think it has been reduced as I can here engine noise between 40kmh to 60kmh where previously I couldn't. But it still aint fixed. Pedders advised they think its a wheel bearing but I'm sceptical. I'm taking the car back to dealer on Tuesday so I'll let you know how it goes but any feedback would be appreciated.
Cheers...
Cheers...
