You won't believe how many finishing touches there are that will "surprise & delight" you.
Flat battery/ voltage drain
I have been going through things, but could not find anything on it. I have had something plugged in for over an hour with the ignition off and the alarm/central locking set, and the LED is still showing. There is a note in the manual that you have to have the ignition on to use them, however not here.Originally posted by brad View Postfor 30 mins. It's in the manual.
Under which section is it?
Thanks.
did u retro fit a columbus (rns510)?
i've heard of the these units draining the battery when retro-fitted to the pre-fl models.
something due to the canbus.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Sorry, had a look but can't find the reference. My 98 Golf had the same feature so I assume it was a universal standard for VW group cars. Mayne I'm wrong.Originally posted by wai View PostI have been going through things, but could not find anything on it. I have had something plugged in for over an hour with the ignition off and the alarm/central locking set, and the LED is still showing. There is a note in the manual that you have to have the ignition on to use them, however not here.
Thanks.
If you switch of ignition & remove keys then turn on radio/cd, how long does that go for? It should be a similar amount of time.
I use the 30 minute feature to charge my phone/GPS.carandimage The place where Off-Topic is On-Topic
If I switch off the ignition and remove the keys, I can't turn the radio/CD on. When the key is removed, the radio/CD goes off.Originally posted by brad View PostSorry, had a look but can't find the reference. My 98 Golf had the same feature so I assume it was a universal standard for VW group cars. Mayne I'm wrong.
When the key is removed, the interior lights come on, and remain on for 10 seconds (set by the combi-display settings). If the door is opened under these circumstances, then the lights come on and remain on for 10 seconds after the door is closed or when the alarm/central locking is activated.
Everything else is off, except the cigarette lighter.
Not necessarily a biggie as I have installed a multi-outlet accessory socket unit and it is a relative simple matter to remove its plug from the lighter socket.
I will raise it with the dealer when it goes in for its first courtesy check.
Thanks anyway.
Hello all,
Thanks for your suggestions. I tried the accessories plug, the indicators, the fog lamps, and looking for any lights on in the car at night...
Annoyingly I can't find any of these things but the warning bell is still there. Its really faint, and seems to be intermittent. I did get a recording of it on my phone last night to play the dealer as they did not hear it.
It only occurs after the car has been sitting for some time. I will hear it when I first open the car, in the morning , but I won't hear it for subsequent trips during the day.
Any suggestions on what I should ask the dealer to check/look for would be appreciated.
An update...
The battery went flat again. So flat that the doors would not open with the remote, and they needed to manually override the gear change to put it into neutral.
It's been towed to the dealer, so fingers crossed this time they can work out what the issue is.
My wife is seriously po'd as this is our only car and last week the dealer said there was no problem.
That's the problem with the reliance on computer technology in modern cars. I discovered this with my Caddy.Originally posted by daft1014 View PostThe battery went flat again. So flat that the doors would not open with the remote, and they needed to manually override the gear change to put it into neutral.
I can't get the transmission out of Park until I have depressed the foot brake.
I can't get the key out of the ignition until the transmission is in Neutral or Park.
I can't put the transmission into Park until I have my foot on the brake because it has to travel through Reverse, even though I have the hand brake on.
Needless to say, when things go wrong with the power supply, you are all locked in or out.
You may have to resort to a portable battery pack, but even here you still need to be able to get the bonnet up so that you can connect it to the main battery. A partner of a cousin of mine has an XY GT Falcon that he only uses on special occasions. Because of this the battery has a tendency to run flat, so he has a portable battery pack so that he can jump start it. That battery is on permanent trickle charge. I asked why he did not trickle charge the main battery, to which he replied that it was a show car and so the trickle charger would not go down well if it was permanently installed in the car, and that it was "easier" to have the portable battery.
I got my car back after being in the dealers after ten days. It took a very long time to identify the problem. At one point they thought they had found the problem, but after swapping out what they thought was a faulty module the problem was still there and they had to keep looking.
The problem was finally identified to be an acc control panel that would turn itself on and draw a significant load.
I have to say I am glad it is under warranty.
