Push on the copper contact switch and see if you can get all speeds working.
If you pull the knob off, you can see all the inner workings.
I tested it all with the multimeter and it was fine. So I reached around the back of the dash and pushed on the plug going into the switch and its all good! So happy!
Thanks for your help man!
1999 MKII Seat Ibiza Cupra Sport
2000 Audi TT Quattro
2000 Audi B5 S4
I repl mine from my parts car as it was only working on hi
too loud and blowing out foam dust...newby works on more settings 23&4 nice
I thing if you pull it out you will find the contacts are worn and you maybe able to bend into place with nosepointpliers
can also send you mine for cheap when I fix it..
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
undo the screw(s)
pull it and rebend the terminals which are not touching where they shoul.
Ihave a used one if u need
many parts from my Cordy fit Ibi and Mk3 !!
cheers
B
